Speakers for 73 B-body WTB? #1212855
04/09/12 02:53 PM
04/09/12 02:53 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
I have a 73 Charger and I am looking to be buying speakers for it soon. I am looking for what would drop in and not involve any cutting of the dash or rear deck.
I think the dash has that funky 4x10 which can be replaced with a plate to hold 2x2.5" round speakers. What about the rear deck?
Anyone sell these as a kit? They need only handle 45w RMS...not looking for a booming amp here...
Re: Speakers for 73 B-body WTB? [Re: cjskotni] #1212856
04/09/12 04:21 PM
04/09/12 04:21 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
6"x9" for the rears is a bolt in.
Re: Speakers for 73 B-body WTB? [Re: cjskotni] #1212857
04/09/12 05:03 PM
04/09/12 05:03 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You can put a pair of 3-1/2" speakers in the single dash speaker hole. Are you sure you don't have speaker grilles off to each side?
I just bought a pair of Infinity Reference series 3032cf speakers for the Imperial.
The Imp had a pair of 3-1/2" speakers as well as a single 4x10 in the dash.
I also picked up a pair of Infinity Reference series 9632cf 6x9 speakers for the rear.
http://www.crutchfield.com/p_1089632CF/Infinity-Reference-9632cf.html
They're still in the boxes so I can't comment on how they sound.
- Stu Harmon
Re: Speakers for 73 B-body WTB? [Re: feets] #1212858
04/09/12 05:13 PM
04/09/12 05:13 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
Feets I have the 3032's in my Talon and they sound pretty freaking good just running off my Pioneer 50w x 4 deck.
Re: Speakers for 73 B-body WTB? [Re: DARTH V8Я] #1212859
04/09/12 05:52 PM
04/09/12 05:52 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
One thing I didn't mention is the rubber surround for the cone. It will get in the way. The factory speaker mounts flush so I will need to drop the new speakers down using a spacer so the cone doesn't get squished against the speaker grille.
- Stu Harmon
Re: Speakers for 73 B-body WTB? [Re: feets] #1212860
04/09/12 05:55 PM
04/09/12 05:55 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Any old 6x9's will fit in the back. For the front, I agree, the best is to run a pair of small speakers. They're not ideally located but they are easy to drop in the middle where that big single was.
Re: Speakers for 73 B-body WTB? [Re: feets] #1212861
04/09/12 05:59 PM
04/09/12 05:59 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
I have 2 3.5 inch Polk Audio DB 351's up front with the adapter found in the new products section and a pair of 6x9 Polk DB 651's in rear. Great sound from these with the Retro Sound unit I have. My rear deck has a 6x9 and a smaller 5x8 opening, I used a spacer from an old 6x9 to lower the one side and it works perfectly.
Re: Speakers for 73 B-body WTB? [Re: T2R9] #1212862
04/09/12 10:24 PM
04/09/12 10:24 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
I think that's what I have in my rear deck as the opening on the driver's side is smaller than that on the passenger side. I am guessing a 5x8" driver's and 6x9" on the passenger.
Why the heck did they do this?? Now I have to buy two sets of speakers and use only one speaker from each set!
Anybody want to go halfsies on a set of 5x8's or 6x9s with me?
I am pretty sure my dashonly has the one 4x10 dead center. I am might go for the plate that can accept the two round speakers to fill that hole for a nice round four speaker system.
Any ideas where you can find a 6x9 spacer to drop the 6x9" speaker down a bit to clear the package tray?
Re: Speakers for 73 B-body WTB? [Re: cjskotni] #1212863
04/09/12 11:24 PM
04/09/12 11:24 PM
Manitoba, Canada
Manitoba, Canada
Even if the hole is smaller, I think it still has the 6x9 bolt pattern. I don't remember having to drill any holes when I put a set of 6x9's in, tho I do remember one side having an odd shaped hole.
Re: Speakers for 73 B-body WTB? [Re: DaytonaTurbo] #1212864
04/10/12 12:30 AM
04/10/12 12:30 AM
Jamestown, Indiana
James74 Offline
James74  Offline
Jamestown, Indiana
i had to drill holes on my 74....
there was a member that has some custom fiberglass inserts on the inner quarters in the trunk. wish i would have saved the pics.....
Re: Speakers for 73 B-body WTB? [Re: cjskotni] #1212865
04/10/12 01:10 AM
04/10/12 01:10 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I used the Infinity Kappa 3.5" in front in the speaker bracket listed in the new deals section.
The speakers sound great for their size. Any 3.5" speaker is not going to have very good bass response. The rear speaker shelf should be able to use 6x9" speakers. In my convertible, I used 6.5" round speakers in the rear arm rest panels. With the top down, it was still hard to get good low bass, so I put an amp and sub in the trunk.
Re: Speakers for 73 B-body WTB? [Re: feets] #1212866
04/10/12 08:29 PM
04/10/12 08:29 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
FWIW...I ran into this on my '77 Royal Monaco Brougham some years back (sorry...the speaker manufacturer I used is no longer in business [Made in USA], so no recommendation to offer). I could not drop the speaker down further on the driver side due to the size of the magnet. I actually had to trim a little webbing on the back of the cluster trim, and it still would not fit. I ended up essentially raising the grilles with a layer of foam gasket material to get the needed clearance.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Speakers for 73 B-body WTB? [Re: DynoDave] #1212867
04/10/12 08:57 PM
04/10/12 08:57 PM
MarkZ Online boogie
Worthy
MarkZ  Online Boogie
Worthy
I can't speak to the fitment, but for the speakers on the rear deck try and come up with some sort of enclosure for the bottoms rather than leaving them open to the trunk. They'll sound on orders of magnitude better.
Re: Speakers for 73 B-body WTB? [Re: cjskotni] #1212868
04/10/12 09:12 PM
04/10/12 09:12 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
I used the 1/2" or so cone spacer from an old 6x9, (The part glued on top to deaden the mount) cut it off and used that as the spacer on top of the new one. I did have to drill new holes and round up some longer screws. No problems. I will get a pic of the install tomorrow.
Re: Speakers for 73 B-body WTB? [Re: cjskotni] #1212869
04/10/12 11:38 PM
04/10/12 11:38 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
The dash one is 4X10, and you can get the dual speaker shaped like the original. There are a couple companies selling them (retrosound).
The back are 6x9.
No cutting involved.
Re: Speakers for 73 B-body WTB? [Re: T2R9] #1212870
04/10/12 11:38 PM
04/10/12 11:38 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
It's Swifty! Swifty, you toad sucker!
Re: Speakers for 73 B-body WTB? [Re: MarkZ] #1212871
04/11/12 10:15 PM
04/11/12 10:15 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Baffles
DynoDave
Member # 12304
Re: Speakers for 73 B-body WTB? [Re: DynoDave] #1212872
04/29/12 05:54 PM
04/29/12 05:54 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Ok guys, I appreciate the feedback so far but now that I have restored the orignal rear speaker openings from where somebody had enlarged them years ago, I have decided what I am looking for.
I have two openings, one is a 6x9" and one is a 5x7". I'd like to put in two speakers that fit the openings (one from each set) and have them drop in from the top like factory. Thing is, seems most aftermarket speakers have the midrange/tweeter tower protruding out which would get squished by the backage tray. I want to use an OEM type tray without having to cut it...
It appears the Retrosound speakers are very dimension-conscious and would drop right in. However, they look almost wimpy and they aren't the cheapest...do they sound better than they look? Anybody here know of an other aftermarket brands that will top mount and fit the openings/package tray without any more mods than maybe drilling holes?
Any experience with the RetroSound brand?
http://www.crutchfield.com/p_068R693V2/Retrosound-R-693.html?tp=91
http://www.crutchfield.com/p_068R573N/RetroSound-R-573N.html?tp=93
Also if anybody here is in the same boat as me with a 71-74 B-body and wants to split two sets to get the speakers they need, I am willing to buy the two sets and half the cost for one of each :-)
Thanks in advance!!
Re: Speakers for 73 B-body WTB? [Re: cjskotni] #1212873
04/29/12 07:41 PM
04/29/12 07:41 PM
Manitoba, Canada
Manitoba, Canada
Why don't you want to fasten a set of 6x9's from the bottom? With small bolts and lock nuts it's not like they're going to fall down.
Re: Speakers for 73 B-body WTB? [Re: DaytonaTurbo] #1212874
04/29/12 08:36 PM
04/29/12 08:36 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
I might go that route if I can't do what I want and not have to spend 250$+ for two sets of decent speakers....
I don't mind doing a bottom mount but then won't I have to run spacers and have them sticking way down into the trunk to get them to clear the recessed speaker opening?
If you guys know of a set I can botom mount with NO spacers needed, then I may consider that route as it would be much cheaper and easier.
