Drive Shaft-Aluminum,Moly? #1212649
04/09/12 12:15 PM
04/09/12 12:15 PM
Northampton Pa
65 NSS 500 Offline OP
Northampton Pa
I wanted to see suggestions for what type of driveshaft and where to get one. I will be replacing my stock drive shaft and want to see what I should get. I am running a 4 speed and slicks on occasion with approx 500 hp. Is aluminum the best or what should I use.
1965 Coronet 500 340 40+ Passon 4sp 12.90 2.6 60' street tires
Re: Drive Shaft-Aluminum,Moly? [Re: 65 NSS 500] #1212650
04/09/12 12:24 PM
04/09/12 12:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I will be getting a drive shaft made shortly... I
am going with moly and will have Dynotech make it..
I'm going moly because its a street rod and its a
bit more durable on the street... I dont think you
will see any weight difference between moly and alum
due to the wall thickness they have to make the alum
Re: Drive Shaft-Aluminum,Moly? [Re: MR_P_BODY] #1212651
04/09/12 01:06 PM
04/09/12 01:06 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
just ordered my new one from Driveshaft Specialists and it will be moly, my old one was an old Mopar Performance welded seam kit from Mancini,, been a good one but it's was time to upgrade.
Re: Drive Shaft-Aluminum,Moly? [Re: dartman366] #1212652
04/09/12 09:46 PM
04/09/12 09:46 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
I just got my moly driveshaft from DoctorDiff.
I sprung for the 1350 joints and it was still a great deal!
Re: Drive Shaft-Aluminum,Moly? [Re: 65 NSS 500] #1212653
04/09/12 09:51 PM
04/09/12 09:51 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Call Dynotech and see what they recommend. They are great guys . Mine is mild steel behind a 550 hp or so small block that goes high 1.30 60' at 3240#. No problems in two years.
Re: Drive Shaft-Aluminum,Moly? [Re: justinp61] #1212654
04/09/12 10:10 PM
04/09/12 10:10 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
I found a new aluminum shaft out of a 3/4 ford van, has 1350 U joints on Craigslist for 50.00 dollars. Cost a 125.00 dollars to have it shortend.
