Banjo Bolt Installation #1212526
04/09/12 08:39 AM
04/09/12 08:39 AM
Louisiana
duckblind Offline OP
Louisiana
Is the proper banjo bolt installation for a 73 charger: put one washer on banjo bolt and then slide the banjo bolt through the hose. Then put another washer on the banjo bolt and screw the bolt into the caliper?
Thanks,
Re: Banjo Bolt Installation [Re: duckblind] #1212527
04/09/12 08:42 AM
04/09/12 08:42 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
There should be a crush washer under the head of the bolt, then one between the hose and caliper.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Banjo Bolt Installation [Re: duckblind] #1212528
04/09/12 08:44 AM
04/09/12 08:44 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Thanks,
Yes
Re: Banjo Bolt Installation [Re: GoodysGotaCuda] #1212529
04/09/12 08:51 AM
04/09/12 08:51 AM
Louisiana
Louisiana
