Re: to much voltage
[Re: superstreet1896]
#1212428
04/08/12 09:55 PM
04/08/12 09:55 PM
Posts: 1,532 off the grid
340B5
off the grid
Is this charging voltage or battery voltage? It's slightly high @ 16.1, but I wouldn't be concerned unless the battery is overcharged when a voltage reading is taken w/ the engine off.
Yeah, it's got a smallblock.
Re: to much voltage
[Re: 383man]
#1212431
04/09/12 12:01 AM
04/09/12 12:01 AM
Posts: 3,905 Oregon
hooziewhatsit
Yep, measure the voltage between the + terminal at the battery, and the voltage on the blue sense wire at the alternator. I'd bet you'll see ~2v there.
(+ Dmm lead on the battery +, and the - DMM lead on the blue sense wire).
If so, you have enough bad connections between the battery and the alternator that it's dropping that much voltage, and making the alt overcharge by that amount.
Re: to much voltage
#1212435
04/09/12 11:31 PM
04/09/12 11:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The race regulator is suppose to maintain 13.5 volts... I think you have problems ... 16 volts is too high for a stock type system(non 16v system).. better check the signal/trigger wire for proper voltage... I wouldnt even mind 14.5 volts but 16 is getting way to high for that system... have you brought up the revs to about 4000 rpm to see what it is there
Re: to much voltage
[Re: 383man]
#1212437
04/10/12 12:34 PM
04/10/12 12:34 PM
340B5
off the grid
When doing an isolation test a factory system will go to 15.7-15.8. Granted, it shouldn't stay there forever. If it does, there is a problem.
Re: to much voltage
#1212438
04/10/12 02:54 PM
04/10/12 02:54 PM
Posts: 1,505 TN
SCATPACK 1
TN
Joel I think if you will check, the voltage regulator you put on is a race only unit that is designed to maintain max charging at all RPM's. I used one of those on my 68 Hemi car when I raced it. You can do a couple of things to reduce your voltage if you are going to use that race style regulator. Put a larger pulley on the alternator to reduce the alternator RPM's and the output. Adjust the belt so it slips a little (not my favorite, but it will work) IF you still have too much Voltage, then you may have to get away from the race regulator and just put in a heavy duty regulator for a truck that has all of the extra lights and power take offs.
Old Geezer Racing
