Fuel system question for blow through #1212405
04/08/12 07:10 PM
04/08/12 07:10 PM
Fort Collins, Colorado
CoDart Online content OP
CoDart  Online Content OP
Hey all! I am in the process of putting a procharger on my 360. I installed a new fuel system a few years ago, I didn't think I would be forced induced. I have 3/8 line and a Holley Hp billet 125 pump, stock fuel tank..deadhead type system. I have a aeromotive boost referanced regulator. Could I use that regulator and run a bypass line back to the tank? Or do I need a fuel cell? Whole new fuel system? Or what do you all think I should do? Any ideas and tips would be great
Re: Fuel system question for blow through [Re: CoDart] #1212406
04/08/12 07:46 PM
04/08/12 07:46 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
I had a 650rwhp street car on e85 and blowthrough... You need a whole
New system! I had a 1000+ wheel fuel system and I'd recommend
The same for any forced induction system. Lots of research and
All the heavy hitter cars run this system and it's dead nutz reliable
Magnafuel pro star 500 pump, -12 sumped tank or cell
I ran a lone 50micron filter before the pump
-10 from pump outlet to a aeromotive 13202 regulator
It's a 4 port just use two. -8 to the bowls
-10 back from the reg to the top of the tank (return)
-8 rollover vent valve. That is very important- it's got to breath
The pump has a bypass valve built in-- cap it
This system is the only way to go... Blower or turbo Rock solid
Pressure that rises with boost. And can run any fuel that goes
Bang!
74 dart sport 440 www.Csucarbs.com
Re: Fuel system question for blow through [Re: shoebox] #1212407
04/08/12 08:04 PM
04/08/12 08:04 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
pic
