Should my volt meter be reading 12v when car is off?
#1212331
04/08/12 03:04 PM
04/08/12 03:04 PM
Posts: 3,287 Dalton, MA
Slipknot440
Dalton, MA
Should my volt meter be reading 12v when the car is off? Its an after market unit I put in my 68.
Re: Should my volt meter be reading 12v when car is off?
[Re: Slipknot440]
#1212332
04/08/12 03:10 PM
04/08/12 03:10 PM
Posts: 26,008 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A fully charged 12V battery should put out about 12.5 volts.
If you have a voltmeter in the car it shouldn't read anything with the ignition switch off, it should only be powered with the switch on.
[Re: Slipknot440]
#1212333
04/08/12 03:53 PM
04/08/12 03:53 PM
Posts: 5,448 So Cal
Sinitro
So Cal
You have connected it wrong... The 12V should only be live when the key is ON.. Find another 12V source to connect to.. Just my $0.02.. ![](/ubbthreads/images/graemlins/wink.gif)
[Re: DaytonaTurbo]
#1212337
04/08/12 08:24 PM
04/08/12 08:24 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
I agree find a switched power source.They tell you to use switched power.It will drain the battery and the gauge might get hot as it will be on 24/7.Rocky
Chrysler Firepower
[Re: Slipknot440]
#1212338
04/08/12 08:25 PM
04/08/12 08:25 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I think I wired it into a full time 12v source is why, will this burn up my battery?
Burn up? No, but it'll put a constant draw on it that you don't want. Find a key switched source. ![](/ubbthreads/images/graemlins/Twocents.gif)
