Page 1 of 5 1 2 3 4 5
How good are the P7 engines for drag racing? #1212125
04/08/12 12:39 AM
04/08/12 12:39 AM
Arkansas
Adrielp Offline OP
Adrielp  Offline OP
Arkansas
Pros, cons and such. Thanks!
Adriel Paradise
Substation Design Engineer III
Re: How good are the P7 engines for drag racing? [Re: Adrielp] #1212126
04/08/12 07:08 PM
04/08/12 07:08 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
Obviously no good at all, seeing your (lack of) response!!
Re: How good are the P7 engines for drag racing? [Re: Oyvind Mopar] #1212127
04/08/12 07:28 PM
04/08/12 07:28 PM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
Type P7 into the Google search box at the top of the page. There are a lot of threads about them. Maybe you can find some info there.
Dennis
Re: How good are the P7 engines for drag racing? [Re: cudaboy] #1212128
04/08/12 08:21 PM
04/08/12 08:21 PM
Arkansas
Adrielp Offline OP
Adrielp  Offline OP
Arkansas
Dennis
I always do my own research but I use the thread to hopefully get to some information a little more easier. In this case its probably a situation where the topic has been brought up before and people don't care to respond again. Unfortunately, I missed that thread lol.
Adriel Paradise
Re: How good are the P7 engines for drag racing? [Re: Adrielp] #1212129
04/08/12 08:29 PM
04/08/12 08:29 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
theres probably 4 guys that have done it,,,that's why there's lack of response
Re: How good are the P7 engines for drag racing? [Re: Adrielp] #1212130
04/08/12 08:32 PM
04/08/12 08:32 PM
Trumbull,CT.
jim sciortino Online content
jim sciortino  Online Content
Trumbull,CT.
To get the most out of them, I have no doubt, when ported and assembled for a dragrace application, they are just fine.
Like the SB-2 chevy in a dedicated drag build, they perform excellent.
Re: How good are the P7 engines for drag racing? [Re: jim sciortino] #1212131
04/08/12 08:41 PM
04/08/12 08:41 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Bondobob R-5/P-7
Here's Bondo on his one and only shakedown pass.
Recall on the tach showed a 6800 RPM max.
I forget what the car weighed.
Re: How good are the P7 engines for drag racing? [Re: S/ST 3040] #1212132
04/08/12 08:46 PM
04/08/12 08:46 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
I really like the sound of that thing. Would have thought more rpm.
Some of the parts can be had for a song. So what is the expensive part? (downside)
Yeah, it's got a smallblock.
Re: How good are the P7 engines for drag racing? [Re: 340B5] #1212133
04/08/12 08:53 PM
04/08/12 08:53 PM
S/ST 3040 Offline
S/ST 3040  Offline
Bob was granny-ing it on the new car. (car, suspesion, brakes, engine, rear, etc.)
It dropped a valve headed for the water box the next round.
Just from memory, I think it went 5.83 @ 114 MPH
He would have been shifting it @ 9000+
Re: How good are the P7 engines for drag racing? [Re: S/ST 3040] #1212134
04/09/12 12:13 AM
04/09/12 12:13 AM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
I know of one running in a 1400# Front engine nostalgia dragster running 7.40's at 180+ on injected alky. The dad is a member on here although I don't think he gets on here too much anymore. Basically ran it the way it ran in a round tracker except for changing over to aluminum rods, and slightly different cam profile, buzzing it to 10,000+ fairly regularly. Not really ideal for index racing but drew a lot of attention and other than occasional spring problems was trouble free. Torque, or lack of it would seem to me the biggest problem in a heavier bodied car without a multi-gear tranny (i.e. more than 2-speed). Fair amount of fab work for oil system, bell housings, starters(etc.) but certainly doable for most builders. The P-7 was definitely designed to be a race engine, suprised you don't see more of them in Comp.
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: How good are the P7 engines for drag racing? [Re: 23T Hemmee] #1212135
04/09/12 01:35 AM
04/09/12 01:35 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I'd like to think they preform very well. I've had a best of 109 mph 6.934 in the 1/8 on glare ice. And that was with a brand new setup. Still working on it.. Getting rid of the leaf springs and putting ladder bars in.
I'm hoping to get it to the asphalt a few times this summer and see how it does.
R5P7 in a duster 1/8 mile ice drag strip
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: How good are the P7 engines for drag racing? [Re: Adrielp] #1212136
04/09/12 03:07 AM
04/09/12 03:07 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
For an all out drag racing application you would start with a set of raw castings that you would send to someone like CFE or Slawko (I know these two companies have done development on these heads)
They are a very good, well engineered engine that can perform well. I do think that a oval track head with a drag racing specific camshaft could also run a decent number also. You won't be running anything under 6500-7000 in stall speed, in an all out application is it going to be closer to 8500-9000.
An all out engine is going to cost plenty of $$$, you're not going to get any change out of $60-80K
Alan Jones
Re: How good are the P7 engines for drag racing? [Re: LA360] #1212137
04/09/12 03:50 AM
04/09/12 03:50 AM
Europa, Estonia
Georg Offline
Georg  Offline
Europa, Estonia
Going to swap my Charger with Valiant soon and prepare to install my R5/P7 into it.
Ofcorse this Valiant dont have best tranny for R5 motor ( PowerGlide with 6500 RPM torque converter ) but car is pretty light....so we will see later this summer hopefully how it works out
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: How good are the P7 engines for drag racing? [Re: LA360] #1212138
04/09/12 11:00 AM
04/09/12 11:00 AM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Maybe that much in Oz with all of the shipping charges you guys have to endure, but my friend in the dragster has less than $20K in his and almost $6K was in the Engler Fuel Injection, and dry sump system. I forgot to mention, they don't have have any provision for wet-sump oiling, so dry-sump is a necessity.
Ronny
John 14:6
Re: How good are the P7 engines for drag racing? [Re: 23T Hemmee] #1212139
04/09/12 11:53 AM
04/09/12 11:53 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
The best( and about only) example of a P7 motor drag racing on this forum was my buddies 68 Dart he raced all summer, year before last.
68 Dart 3000 pounds with driver
904
Old busch restrictor plate motor. Small 248/258 roller cam, compression was at about 12 to 1.
He used old w2 2 inch headers he made work
4150 carb, forget how big.
Car went low 9.40's at 142-143 MPH, probably put 50-60 passes on it, then sold the motor to one guy, and the car to another.
So with probably not the " best" p7 motor to use, he still got it to fly.
With bigger cam and more compression i have no doubt it could have threatened the 8's. Those heads are just darn good.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: How good are the P7 engines for drag racing? [Re: B3422W5] #1212140
04/09/12 12:13 PM
04/09/12 12:13 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Wow, a little arrogant there.. Just cause I don't race asphalt, I'm not good enough to be an example??? I'm glad your BUDDY is the only one GOOD enough to be taken into consideration in this forum... Just another example of all you clicky azzholes on here... IF you don't drag race assphalt you're no good...
SDG Motorsports
Re: How good are the P7 engines for drag racing? [Re: DemonDust] #1212141
04/09/12 12:18 PM
04/09/12 12:18 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Last i checked this is a drag racing forum. I wasnt trying to be arrogant, just stating a fact, he actually raced one a whole season. Only person i know who has done so.
Lighten up dude, i didnt say he was good, bad or indifferent, just said he raced it, and posted his basic combo and what it ran.
Your ice racing deal has zero to do with this forum, unless they changed it from drag racing.
I have posted on here for 10 years, go pack sand.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: How good are the P7 engines for drag racing? [Re: B3422W5] #1212142
04/09/12 12:30 PM
04/09/12 12:30 PM
west coast
P
produster Offline
produster  Offline
P
west coast
The one down fall I have heard on these motors is the valve stem size and running a bigger spring pressure for bigger cam for drag racing. But I know they, valve guides can be made bigger.
I think that is the biggest down fall of these motors for drag racing. A cam change, better intake, bigger carb, a little off the head to up the compression and you can look in upwards of 1000hp. If given the time and effort you could have a killer set up.
Only issue is the limited amount of trans stuff. Jesse is the only one I know doing some sort of adapter.
When my project is a little more firm I will reveal what I am doing and let the nay sayers tear it apart.
Re: How good are the P7 engines for drag racing? [Re: B3422W5] #1212143
04/09/12 12:31 PM
04/09/12 12:31 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Are you kidding me?? I know it's a drag racing forum you frickin Douche. How is drag racing on ice not drag racing??? Please tell me sir why I don't qualify? Sorry my 7 years isn't good enough for your 10.. Once again you go with I'm bigger and better then you...
And I have 3 seasons drag racing on mine...
SDG Motorsports
Re: How good are the P7 engines for drag racing? [Re: produster] #1212144
04/09/12 12:32 PM
04/09/12 12:32 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Bondo Bob also does adaptors, My buddy used one of his and it worked flawlessly.
1.41 best 60 foot
6.60 at 103.90 1/8
