Re: Modern stereo
[Re: Shawnb]
#1212102
04/08/12 03:06 AM
04/08/12 03:06 AM
Posts: 1,235 Phoenix, AZ
Jjs72D
Deep in the closet
Deep in the closet
Phoenix, AZ
Do you have a rally dash? I know a guy with a 70 Road Runner with rally guages. He did a modern stereo recently and when he pulled the plastic radio plate, there was a wide rectangle hole, factory stock already. He didn't have to cut anything to fit his Alpine CD stereo. Maybe your dash frame is similar? Jeff
Re: Modern stereo
[Re: Shawnb]
#1212105
04/08/12 04:51 AM
04/08/12 04:51 AM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
I just use a small Lepai Tripath amplifier that I have in my glovebox wired into two small Pioneer speakers bolted together up in the standard speaker grille area. It doesn't sound great, but it sounds good enough for an old car. Plus it's cheap and you can't tell anything is non-stock save for the wire hanging from underneath my dash for my music player!
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Modern stereo
[Re: Jjs72D]
#1212107
04/08/12 12:59 PM
04/08/12 12:59 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
I just reread the original post and I think that I get it. You need a factory appearing plastic radio faceplate for a modern radio? Jerry had to cut the stock one to fit the hole. Maybe you can buy the faceplate for an AM radio application and do the same thing. There should be new ones available, or try swap meets for a restoreable one. Jeff
either this or the modified delete plate will be the best option. plates are available through any number of vendors that support the site.
Re: Modern stereo
[Re: Shawnb]
#1212108
04/08/12 01:17 PM
04/08/12 01:17 PM
Posts: 2,295 dark side of the moon
Dougsmopars
ebay item number 120889040536 new reproduction am/fm stereo. Comes in 68 or 69 style. I bought one for my 68 GTX. It sounds awsome and looks stock with no mods needed to dash or bezel
Re: Modern stereo
[Re: Shawnb]
#1212113
04/08/12 04:01 PM
04/08/12 04:01 PM
Posts: 5,441 So Cal
Sinitro
So Cal
I am about complete with the restoration on a 69 A12 six pack bee. I would like a modern stereo in the place of the old missing one. I assumed some company would have made a dash plate for the standard size and shape for a stereo like you would buy at Best Buy. I searched on line and cant find one. I also have a 68 Super Bee and what I did for that one was cut the factory plate to the shape of the stereo. This time I didnt want to do that. I thought of buying a delete plate and cutting it but id rather just buy one for a modern stereo. Any ideas? Thanks in advance
EZ solution... Buy a repro Radio DELETE trim plate, using the Dremel & cutting wheel cut out a 2" x 6" hole matching a single DIN CD player nose piece. Check out Crutchfield, they carry many brands/models and these run from $79 to $299.. There is plenty of space, the other thing is to make a short rear chassis support bracket to fit into the factory mount.
Also when installing the CD player, suggest you install a pair of 3 1/2" 2-way speakers in the front OE 4x10 space. For the rear install a pair of 6x9", they bolt rite it.
The majority of aftermarket CD players include a 15W x 4 built-in amplifier which is more than adequate unless you want the bass thumper.
Now you have a reasonable sound system not big $ plus if you want to return to a numbers matching OE look, no panel cutting.. In my 70 RR I did that and also have a Pioneer CD player that takes an iPod through its USB, drops rite into the glove box and have 1500 songs in my jukebox.
Just my $0.02..
