Re: 1997 Ram 1500 - Speedometer stopped working
[Re: Alaskan_TA]
#1212014
04/08/12 04:57 AM
04/08/12 04:57 AM
Posts: 357 Lake Elmo, MN
Evil Monkey
Lake Elmo, MN
If the Ram speedometers are anything like the Neons of that era, they had a problem with cold solder joints in the speedometers. I've had 2 instrument panels in my '98 Neon and both had this problem. Both the speedometer and odometer worked intermittently, then not at all. For the Neon, after pulling the instrument panel, you can touch up the solder joints on the circuit board where the speedometer is connected, and it starts working again. If I looked at these solder joints (before touching up), it looked like there was a small circular crack in the solder around the post in the joint. I needed my reading glasses to see the cracks. This may or may not be a problem with the Rams, but since they come from the same era, it might be worth looking at.
1974 'Cuda 360/TKO
1990 Ram Van
1998 Neon
[Re: Alaskan_TA]
#1212017
04/10/12 11:44 AM
04/10/12 11:44 AM
Posts: 6,480 Kingston, IL USA!
gts340swinger
Kingston, IL USA!
My 99 Ram had the same symptom and the ABS light also came on. Mine had a bad speed sensor in the rear axle housing. Easy to fix. Same thing happened on my '00 Chrysler but this one was on the trans. Even easier fix.
I agree the Neons had a speedo problem that wasn't a speed sensor. It was also intermittent. My mother had one that did this. When I gave the car to a friend he found the fix online and repaired it rather quickly and now it's fine.
Mr. Norm's "Fanatic" (idiot) 71 Mr. Norm's Demon GSS 77 Mr. Norm's personal B250 GSS van 76 Mr. Norm's KZ900 Motor Sports Special 69 Mr. Norm's M code Dart GTS 69 D100 68 Barracuda 64 Valiant V200 07 Charger Daytona SST 6 speed test mule.
