best way to slow a car down other than throttle stop
#1211899
04/07/12 06:20 PM
04/07/12 06:20 PM
Posts: 650 High Ridge MO.
MOPARCHAS
High Ridge MO.
NHRA license has expired and don't want to spend all the money and time to renew it for as little as I go racing just asking in case they tell me to slow it down thanks Charlie 9.61@138.27
Re: best way to slow a car down other than throttle stop
[Re: MOPARCHAS]
#1211901
04/07/12 06:41 PM
04/07/12 06:41 PM
Guitar Jones
Have you seen those restrictor plates that you can slide in and out? Takes like 5 minutes to change them.
[Re: Guitar Jones]
#1211902
04/07/12 07:11 PM
04/07/12 07:11 PM
Short shift at 3000 RPM.
#1211903
04/07/12 08:38 PM
04/07/12 08:38 PM
Posts: 1,532 off the grid
340B5
off the grid
Drop the shift points. Sounds like the perfect car for 10.0 index.
Yeah, it's got a smallblock.
[Re: 451Mopar]
#1211906
04/08/12 12:47 AM
04/08/12 12:47 AM
Posts: 13,198 aZLiViN
J_BODY
aZLiViN
[Re: MOPARCHAS]
#1211907
04/08/12 12:59 AM
04/08/12 12:59 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I use a mech throttle stop on the car and fine tune it with the launch and shift rpm... works great... this is the stop I made to fit my 1050 dom
[Re: MOPARCHAS]
#1211908
04/08/12 01:37 PM
04/08/12 01:37 PM
Posts: 145 B.C. Canada
hankcrank
B.C. Canada
If you use a throttle cable this is a simple and easy way to slow your car down by not having the carb open all the way.You still floor the gas pedal but the carb only opens part way. You adjust it by changing the the location of the throttle position holes in the little spacer. I used a little piece of aluminum and drilled some holes to make the spacer....more holes the slower the car.Good luck
[Re: dartman366]
#1211910
04/08/12 06:32 PM
04/08/12 06:32 PM
Posts: 687 Ohio
Chad Bittle
Ohio
thats a pretty handy Idea, not that I need to slow mine down.
You're only aloud to use body panel washers....sorry, those are the rules.
[Re: MOPARCHAS]
#1211911
04/08/12 08:43 PM
04/08/12 08:43 PM
Posts: 43,213 Bend,OR USA
Cab_Burge
Years ago we reaced a duster with a 440 braaket motor with a M.W. top end on it with both carbs, it was about four tenths under the index to start with. We found that by shifting it higher(7000 RPM instead of 6400 RPM into both second and third instead of lower we could slow it down a tenth. If we shifted it at 5000, 5500 or 6000 RPM it would slow down maybe .030 to .050, not a ful tenth. this was before delay boxes and electronic throttle stops, a long,(1984) long time ago Adding weight is probally the better way, put it in the middle of the car between the axles
