What blackout paint lower radiator support ? #1211777
04/07/12 05:40 PM
04/07/12 05:40 PM
K
kielbasa Offline OP
kielbasa  Offline OP
K
My AAR was sloppily repainted years ago and am trying to undo some damage - the radiator support and surrounding was oversprayed with body color, I'd like to respray black (rattlecan if possible)again.
Satin, semigloss? Thanks!
Re: What blackout paint lower radiator support ? [Re: kielbasa] #1211778
04/07/12 08:08 PM
04/07/12 08:08 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
This what I like to use.
Re: What blackout paint lower radiator support ? [Re: Challenger 1] #1211779
04/08/12 09:44 AM
04/08/12 09:44 AM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
I could be wrong but I thought that the area behind the grill was blacked out. nothing else. It does look better with more blacked out.
Re: What blackout paint lower radiator support ? [Re: convx4] #1211780
04/08/12 01:03 PM
04/08/12 01:03 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
depends on what the painter felt like doing. Every car is different. The F8 Duster Im working on was painted all the way down like shown above.
Re: What blackout paint lower radiator support ? [Re: convx4] #1211781
04/08/12 01:37 PM
04/08/12 01:37 PM
Cincinnati, Ohio
Cincinnati, Ohio
The bottem of the core support shows when the car is togeather.
Re: What blackout paint lower radiator support ? [Re: Challenger 1] #1211782
04/09/12 11:40 AM
04/09/12 11:40 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Here is a pic of a survivor hemi road runner. Notice how little was painted compared to most of todays restorations.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: What blackout paint lower radiator support ? [Re: MOPARMIKE69] #1211783
04/09/12 11:54 AM
04/09/12 11:54 AM
Cincinnati, Ohio
Cincinnati, Ohio
I only posted pictures so the OP could see the shade of black paint. I have no idea how it was from the factory.
Post deleted by moparts [Re: kielbasa] #1211784
04/09/12 02:38 PM
04/09/12 02:38 PM
Re: What blackout paint lower radiator support ? #1211785
04/09/12 04:50 PM
04/09/12 04:50 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Obviously the paint is chipped and weathered. DUH. I posted this not in direct response to anything that has been posted in this thread. BUT you can see that there is no way they painted a uniform total covering of black out like 90% of todays restorations. The sparce pattern is visible on this car and several other survivor cars I have.
Here is a pic of a 5600 mile car no chips or weather.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: What blackout paint lower radiator support ? [Re: MOPARMIKE69] #1211786
04/09/12 04:53 PM
04/09/12 04:53 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Other side
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: What blackout paint lower radiator support ? [Re: MOPARMIKE69] #1211787
04/09/12 04:58 PM
04/09/12 04:58 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
If you do not have pics of your car with the original pattern to document your exact car, then what ever you do is a guess. The reason it was done was so no body color showed through the grill and under the bumper. Therefore you either shoot it sparce like the factory or complete like an over restoration.
Another survivor. 26,000 mile untouched car.Hardly any paint behind the bumper. Painted behind grill and very sparce below the bumper.
Oh and by the way the color used on the Challenger does not have enough sheen compared to the survivor pic I posted of the documented 5600 mile bee.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: What blackout paint lower radiator support ? [Re: kielbasa] #1211788
04/09/12 05:22 PM
04/09/12 05:22 PM
CT
1932chrysler Offline
CT
I would use this as a guide
1932 Chrysler CI Sedan
1956 Pontiac Catalina Sedan
All Makes & Models Are Special
Post deleted by moparts [Re: MOPARMIKE69] #1211789
04/09/12 07:20 PM
04/09/12 07:20 PM
Re: What blackout paint lower radiator support ? #1211790
04/09/12 09:32 PM
04/09/12 09:32 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
It's best to remember that the black was sprayed from underneath the car. I have typically seen more paint on the bottom of items than on the front.
I have had some that had a lot of paint in some areas and then very little in others.....on the same car. Besides the varying amount of paint car to car.
The only thing that rivals the variations on the rad harness black-out is the variations on the amount of paint on the engines. Same thing there; little to no paint some places while other places had it running off.
On my restos, I usually cover the area behind the grill pretty well with a satin black. I just want to be sure that there is no body color showing through the grill. That is a personal pet peeve of mine.
Master, again and still
