Mig welding and blowing holes
#1211756
04/07/12 05:22 PM
04/07/12 05:22 PM
Posts: 339 California
moparbroz
California
I am burning holes through the original sheet metal on my '72 Satellite. Is the wire speed not fast enough? It's a Lincoln flux wire unit with a hi-Lo setting only.
Hebrews 11:1
Re: Mig welding and blowing holes
[Re: radar]
#1211759
04/07/12 08:11 PM
04/07/12 08:11 PM
moparbroz
California
Awsome! Thank you so much! Quote:
I'm a pretty amateur welder but if you can't control the heat you'll have to match the speed up till it's right on some practice scraps (bead sinks in just right, bacon cooking sound). If the wire speed gets to high it will want to make tall welds with poor penetration that require lots of grinding, or even not melt in fast enough and push you off the puddle. If the LO setting is just too high for the metal thickness you might be able to get away with just not hitting it for very long(tiny tack welds). As always proper gaps and especially clean fresh steel showing are super important. For body work you often want a million tack welds anyway- keep moving around to keep the heat from warping your panels.
Hebrews 11:1
[Re: kenworth_goose]
#1211763
04/07/12 09:47 PM
04/07/12 09:47 PM
Posts: 62 south jersey
welderboy
south jersey
The best weld would be with fluxcore wire and shielding gas. I was amazed at how good it works.
Never heard of that - don't get it, but may be worth a try...
[Re: moparbroz]
#1211767
04/08/12 12:07 PM
04/08/12 12:07 PM
Posts: 5,048 Atlanta Indiana
Dave Watt
Atlanta Indiana
Sometimes there is too much gap between the panels. If that's the case you might need to lay the gun down horizontally with the panel versus perpendicular. This will make it easier to bridge the gap.
[Re: Dave Watt]
#1211768
04/08/12 01:25 PM
04/08/12 01:25 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
You can also use aluminum to back up the weld. I do this all the time and works just fine. Flux core is definitely not the first choice for sheet metal but it can be done.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: welderboy]
#1211771
04/08/12 07:03 PM
04/08/12 07:03 PM
moparbroz
California
I know but not financially feasible right at the moment unfortunately. Quote:
Better off with solid wire and shielding gas! You'll be much happier!!
Hebrews 11:1
[Re: Dave Watt]
#1211772
04/08/12 07:08 PM
04/08/12 07:08 PM
moparbroz
California
Great idea! I will try that! Quote:
Hebrews 11:1
[Re: moparbroz]
#1211774
04/09/12 09:09 AM
04/09/12 09:09 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I kicked myself for waiting so long before getting the gas shielding set-up on my welder.
immediately my welds went from splattery bird poop to nearly perfect looking beads. can't wait till I get back on my car and welding sheet metal with it.
going to gas is not expensive. you reverse the polarity on the welder from the flux core wire, and you can buy a regulator from Habor Freight for $20, then hit up your local TSC for a small bottle. I think it cost me about $200 to set up the gas shielding.
when restoring a car, $200 should NOT break the budget, or your car's restoration is really going to suffer!
remember it's a hobby. take your time, enjoy it, and do it right. if setting up the gas shielding means you wait a few extra months before buying the next replacement panel, then so be it. your results WILL be better
**Photobucket sucks**
