Brake Bleeding 73 RR #1211628
04/07/12 12:33 PM
04/07/12 12:33 PM
pa
1969Coronet Offline OP
pa
I bled the brakes on my 73 Roadrunner and they seemed to stiffen up but brake fluid is overflowing out of the front chamber of the master cylinder. The lid seems pretty tight and it had a good gasket on it. I bought a new one anyway but same thing. Any suggestions on how to diagnose the issue?
thanks
69 Coronet
73 Road Runner
05 Trailblazer
86 GMC 1500
05 Caravan
Re: Brake Bleeding 73 RR [Re: 1969Coronet] #1211629
04/07/12 01:11 PM
04/07/12 01:11 PM
Mid Michigan
Coronet-R/T-Rag Offline
Mid Michigan
I just replaced my master and had to "tweak" the wire rod that holds the lid on. I put it in a vice and compressed it a bit on the front to add more tension when pulling it over the lid. It stopped my leak.
