Replacing rear wheel studs 8.75 #1211010
04/06/12 04:13 PM
04/06/12 04:13 PM
Inver Grove Heights MN
74RR Offline OP
74RR  Offline OP
When I replace the longer wheels studs with the standard length studs on my 8 3/4 do I need to pull the axles to get the studs out? Is there a easier way of doing this?
Re: Replacing rear wheel studs 8.75 [Re: 74RR] #1211011
04/06/12 05:02 PM
04/06/12 05:02 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Pull the shafts, press out the old ones and press in the new ones. If you hammer them out, you could bend the flange. If you pull them in, you could stretch the threads. Press them both ways. Tim.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Replacing rear wheel studs 8.75 [Re: astjp2] #1211012
04/06/12 05:12 PM
04/06/12 05:12 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Been using a hammer to knock out the old ones and installing the new with washers and a lug nut screwed on backwards for many years and never have a flange or thread go bad. As Tim says you could pull the axles and pay to have the studs pressed in and out if you want.
Re: Replacing rear wheel studs 8.75 [Re: stumpy] #1211013
04/07/12 10:10 AM
04/07/12 10:10 AM
74RR Offline OP
74RR  Offline OP
We got them out. Wasn't too bad at all. Thanks for the help!
Re: Replacing rear wheel studs 8.75 [Re: 74RR] #1211014
04/07/12 04:31 PM
04/07/12 04:31 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
good,so what method did you use?
Re: Replacing rear wheel studs 8.75 [Re: stumpy] #1211015
04/07/12 04:35 PM
04/07/12 04:35 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I use either washers or oversized nuts for backing to pull back in using a lug nut flat side to draw against with an air wrench.
