Re: 1970 ebody manual shift steering column
[Re: gregok]
#1210913
04/06/12 12:52 PM
04/06/12 12:52 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
70 Manual shift & floor shift auto are the same... 71 has the tab you depress in order to turn the key to the steering locked position....
[Re: gregok]
#1210915
04/06/12 02:18 PM
04/06/12 02:18 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
So the 70 has no tab to depress, that should be easy to spot. Thanks for the tip on the floor shift auto/manual shift being the same. I see on ebray they usually list the item as manual or auto shift.
Actually I think you'll see its auto or manual steering... that does make a difference.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#1210916
04/06/12 03:16 PM
04/06/12 03:16 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
I think you mean power or manual steering
[Re: Morty426]
#1210917
04/06/12 08:28 PM
04/06/12 08:28 PM
Silver70
Rust Belt, SW PA
That is correct
[Re: gregok]
#1210919
04/07/12 02:26 AM
04/07/12 02:26 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Yes, manual steering box is shorter so the column is longer...
