Re: Conversion u-joint strong as 7260 u-joint?
[Re: astjp2]
#1210727
04/06/12 12:20 AM
04/06/12 12:20 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
Been using the conversion u-joint on 3 cars for many years..
71 dart 360 has run 10.90s in Vegas with transbrake for 5 yrs now...
71 Demon 360 has run 11.10s in Vegas, now with transbrake going on second season.
you should not have any problems with the 7260/7290 u-joint.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#1210729
04/06/12 12:34 AM
04/06/12 12:34 AM
Posts: 4,930 Tri-Cities, Washington
VITC_GTX
Are your conversion u-joints solid or are they greasable?
[Re: biginchmotor]
#1210731
04/06/12 01:17 AM
04/06/12 01:17 AM
VITC_GTX
Dana/spicer # is 5-527x. That is the one I have been using with no problems, John.
Looks like his part number is a greaseable unit. Do they make a solid conversion u-joint?
[Re: 340SHORTY]
#1210735
04/06/12 11:42 AM
04/06/12 11:42 AM
RapidRobert
You should be fine. I would source a solid one if available. #1 make sure the ujoint moves free in both planes. with the shaft horizontle supported just off the ground I rap the 2 "ears" between the shaft and the ujoint with the pein end of a medium hammer to square it up & free it after knocking in the ujoint
