Fuel delivery issue #1210609
04/05/12 06:03 PM
04/05/12 06:03 PM
beentheredonethat
AverageJoe Offline OP
beentheredonethat
I'm more of a paint/body guy - not the sharpest with engines : I can get fuel to the carb if someone holds the butterfly closed , simply cranking over isn't pulling enough fuel to fire it off - doesn't want to stay running either. Just bolted a new carb and fuel pump on. Had the same issue a few months ago and found crack in fuel line (sucking air) acting the same way except fuel will make it up with butterfly closed ..... where should I look for a cause this time ?
Re: Fuel delivery issue [Re: AverageJoe] #1210610
04/05/12 06:08 PM
04/05/12 06:08 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Double, triple check for any leaks on the suction side.
Make sure the sock in the gas tank is not clogged.
Be sure the tank is vented properly.
Re: Fuel delivery issue [Re: AverageJoe] #1210611
04/05/12 08:34 PM
04/05/12 08:34 PM
hook a can of gas to the pump inlet w a neoprene line & retry it. That'll tell you if the prob is in the pump/pushrod (BB)/carb filter or if it's rearward in the hard and neoprene lines
Re: Fuel delivery issue [Re: RapidRobert] #1210612
04/05/12 09:32 PM
04/05/12 09:32 PM
Cincinnati, Ohio
Cincinnati, Ohio
Good idea...
