Re: drum brake spindles used with disc brakes???
[Re: Blown61]
#1210584
04/05/12 08:32 PM
04/05/12 08:32 PM
Posts: 905 SD
zrxkawboy
SD
I have an AAJ kit on my 57 Plymouth. Check their website; they may also list a kit for newer cars.
It's Swifty! Swifty, you toad sucker!
[Re: astjp2]
#1210589
04/06/12 03:26 PM
04/06/12 03:26 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
I have $50.00 junk yard Bosch 2005 crown Vic rotors and calipers installed on the drum spindles and hubs.
I had brackets made from 3/8" thick 4140 moly steel. Brackets cost around 120.00 to build. Tim
Very nice, who did the work? What car did you put these on?
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: astjp2]
#1210591
04/06/12 05:57 PM
04/06/12 05:57 PM
Andrewh
I had the brackets water jetted at a local shop and I did the rest. They are going on a 68 Charger.
I have a smaller caliper setup that I didnt use so if anyone wants it, PM me for details. Tim
what bearings did you have to use to get the 2005 ford rotor to work on the 68 charger spindle?
