drum brake spindles used with disc brakes??? #1210580
04/05/12 04:42 PM
04/05/12 04:42 PM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
Is there a conversion kit for this?
Re: drum brake spindles used with disc brakes??? [Re: Blown61] #1210581
04/05/12 04:57 PM
04/05/12 04:57 PM
PEI Canada
chromedome426 Offline
PEI Canada
Yes, Wilwood has a kit to put disc brakes on drum brake spindles.
Re: drum brake spindles used with disc brakes??? [Re: chromedome426] #1210582
04/05/12 04:58 PM
04/05/12 04:58 PM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
Thanks!
Re: drum brake spindles used with disc brakes??? [Re: Blown61] #1210583
04/05/12 05:18 PM
04/05/12 05:18 PM
Andrewh Offline
Andrewh  Offline
scaredbird makes a set too.
but be aware, they push the wheel out. so if your tires already fill the wheel well, it will go out past.
Re: drum brake spindles used with disc brakes??? [Re: Blown61] #1210584
04/05/12 08:32 PM
04/05/12 08:32 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
I have an AAJ kit on my 57 Plymouth. Check their website; they may also list a kit for newer cars.
It's Swifty! Swifty, you toad sucker!
Re: drum brake spindles used with disc brakes??? [Re: Blown61] #1210585
04/05/12 09:41 PM
04/05/12 09:41 PM
AndyF Offline
AndyF  Offline
Viper calipers hung on drum knuckles.
Re: drum brake spindles used with disc brakes??? [Re: AndyF] #1210586
04/05/12 11:00 PM
04/05/12 11:00 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I have $50.00 junk yard Bosch 2005 crown Vic rotors and calipers installed on the drum spindles and hubs.
I had brackets made from 3/8" thick 4140 moly steel. Brackets cost around 120.00 to build. Tim
Re: drum brake spindles used with disc brakes??? [Re: astjp2] #1210587
04/06/12 01:54 PM
04/06/12 01:54 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
pic 2
Re: drum brake spindles used with disc brakes??? [Re: astjp2] #1210588
04/06/12 01:55 PM
04/06/12 01:55 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
pic 3
Re: drum brake spindles used with disc brakes??? [Re: astjp2] #1210589
04/06/12 03:26 PM
04/06/12 03:26 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
Very nice, who did the work? What car did you put these on?
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: drum brake spindles used with disc brakes??? [Re: Secret Chimp] #1210590
04/06/12 04:55 PM
04/06/12 04:55 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I had the brackets water jetted at a local shop and I did the rest. They are going on a 68 Charger.
I have a smaller caliper setup that I didnt use so if anyone wants it, PM me for details. Tim
Re: drum brake spindles used with disc brakes??? [Re: astjp2] #1210591
04/06/12 05:57 PM
04/06/12 05:57 PM
Andrewh Offline
Andrewh  Offline
what bearings did you have to use to get the 2005 ford rotor to work on the 68 charger spindle?
Re: drum brake spindles used with disc brakes??? [Re: Andrewh] #1210592
04/06/12 06:13 PM
04/06/12 06:13 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
It is using the stock B-body hubs with the crown vic rotors..you remove the drums from the hub, swap the wheel studs for longer ones and then slide on the crown vic rotors. I am going to use the Moroso 46180 wheel studs or allstar studs. Tim
http://www.ebay.com/itm/Allstar-Wheel-St...=item56498d2361
Re: drum brake spindles used with disc brakes??? [Re: astjp2] #1210593
04/09/12 12:10 PM
04/09/12 12:10 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
astjp2 -
I got some Vic rotors and calipers awhile back to attempt the same thing you’ve done (but on a C-body). I was hoping to use a Mopar floating single-piston caliper (’75-89 era) with M-body brackets + adapter and tuck it under a 15” wheel. That would hold the factory piston-bore balance but give me an extra .67” of rotor diameter. Overall, it was a no-go under a 15” rim, and it barely fits under the 16” Vic rim (and the adapter looks to be complex vs a flat plate). Neither the drum spindle nor disk spindle looked to be any easier as far as adapter plate.
So I switched horses to the Vic calipers and those look a lot easier, but not as clear-cut as yours.
So:
1. Is that the 12.42” rotor of the 98-02 Vic or the 12.02” rotor of 03-10? The smaller diameter should give more room but it is shallower and throws the caliper deeper into the rim and didn’t seem to give any more clearance for the caliper.
2. Looks like you're using 03-10 calipers? The smaller caliper setup you mentioned – what did it come from?
3. What dia wheels will you be using?
