Alternator bracket question - '69 roadrunner w/AC #1210380
04/05/12 03:53 AM
04/05/12 03:53 AM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
Is this bracket correct for 1969 roadrunner with A/C? I was looking at the assy drawings for this and it shows a bracket that looks like this but it also says "B-Body Similar". I have what are supposed to be correct length belts (measured them @ 60 inches)however they are to long for my setup. Everything is correct otherwise including compressor clutch. Do B-body cars use a different bracket that allows for more adjust travel?
Re: Alternator bracket question - '69 roadrunner w/AC [Re: 70mopes] #1210381
04/05/12 03:59 AM
04/05/12 03:59 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Looks right to me...
Re: Alternator bracket question - '69 roadrunner w/AC [Re: 1_WILD_RT] #1210382
04/05/12 09:07 AM
04/05/12 09:07 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Here is a 1969 Charger setup to compare to
Re: Alternator bracket question - '69 roadrunner w/AC [Re: gtx6970] #1210383
04/05/12 11:46 AM
04/05/12 11:46 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Than what the heck does he have... I figured with the leg going back to the engine mount it was correct but obviously I was wrong...
Re: Alternator bracket question - '69 roadrunner w/AC [Re: gtx6970] #1210384
04/05/12 12:48 PM
04/05/12 12:48 PM
PA
BTTG Offline
BTTG  Offline
PA
same as my 69 R/T
Re: Alternator bracket question - '69 roadrunner w/AC [Re: BTTG] #1210385
04/05/12 05:23 PM
04/05/12 05:23 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
That would be the one I need. Anyone have one? The search is on. Thanks.
Re: Alternator bracket question - '69 roadrunner w/AC [Re: 1_WILD_RT] #1210386
04/05/12 08:47 PM
04/05/12 08:47 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
You arent wrong....the pic that Bill posted has the same leg as well...
Mine does too....
1MYTGTX
Re: Alternator bracket question - '69 roadrunner w/AC [Re: 1_WILD_RT] #1210387
04/05/12 08:57 PM
04/05/12 08:57 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
if you look at the picture Bill posted the one he has is shorter than it should be . He could get away with using shorter belts . I think I have that bracket in a pile of A/C junk in the basement .
Re: Alternator bracket question - '69 roadrunner w/AC [Re: JohnRR] #1210388
04/05/12 09:49 PM
04/05/12 09:49 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
Hey John.. could you check it out for me? They are definitely two distinctly different pieces. I have the correct belts already and would like to use them... not to mention the right part. I am trying to get this rig spot on.
Re: Alternator bracket question - '69 roadrunner w/AC [Re: 70mopes] #1210389
04/05/12 10:50 PM
04/05/12 10:50 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I have a bunch of A/C parts I've been collecting to put air back on my '70 383 Challenger R/T. Are the parts the same as shown ('70 vs. '69 )? Is there a difference 383 vs. 440?
Re: Alternator bracket question - '69 roadrunner w/AC [Re: 6bblgt] #1210390
04/05/12 11:21 PM
04/05/12 11:21 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
69-71 are the same 383 uses a adapter bolted to the passenger head to relocate the bolt hole up to where a 440's taller deck would locate the hole.... So adapter & the rear alternator spacer is shorter to compensate for the thickness of the adapter... The compressor stabilizer tube brackets are different due to deck height also the A/C compressor rear mount is different to compensate for the deck height.. Stuff on the front of the engine is the same...
Re: Alternator bracket question - '69 roadrunner w/AC [Re: 1MYTGTX] #1210391
04/06/12 08:49 AM
04/06/12 08:49 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Every single piece of this is off of a 1969 charger 383 car so I had to find the 440 rear compressor brackets. Ft bracket is the same be it 383 or 440
Like mentioned,, all of it is the same EXCEPT the aforementioned adapter bracket that bolts to the pass side head. And the 3 rear brackets on the backside of the compressor are all unique to there respective application be it 383 versus 440
Re: Alternator bracket question - '69 roadrunner w/AC [Re: gtx6970] #1210392
04/06/12 08:50 AM
04/06/12 08:50 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
lower bracket
Re: Alternator bracket question - '69 roadrunner w/AC [Re: gtx6970] #1210393
04/06/12 08:52 AM
04/06/12 08:52 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Keep in mind, the idler bracket spacer is unique to 1969 and later
in 1967 and 1968 the 2 tubes are equal length
