Flat black paint question
#120980
09/15/08 01:45 PM
09/15/08 01:45 PM
Posts: 163 Winnipeg, MB
sreinheimer
Winnipeg, MB
I just painted my 67 dart flat black with Delfleet flat black by PPG. I painted it once with sherwin-williams basecoat black and was not happy with the shine so i repainted it flat black. My problem is that the paint turned out to be very uneven with spots that are alot shiner than others. It looks like there is more paint on these spots than the rest. The texture of the paint is cosistent along the whole car and it doesnt feel rough like it is overspray What could have caused this? too much paint or too close to the car? Is there anything i can do to even out the color? I am willing to try anything before i am forced to repaint it a third time. Thanks alot.
69 Dodge Charger - first full resto
05 Dodge Magnum R/T
Re: Flat black paint question
[Re: sreinheimer]
#120982
09/15/08 05:31 PM
09/15/08 05:31 PM
Posts: 21,831 Kirkland, Washington
Pacnorthcuda
Flat, or even matte,semi flat, satin, semi gloss paints CAN be very application dependant--much more so than the usual gloss. You are finding this out. As Daytona stated the evenness of each coat is really important, but so is the condition of the substrate. Uneveness in substrate--like an area of filler next to an area of paint can produce the unevenness you describe. The only fix, short of another coat, is to abrade/polish the surface with a cutting compound, rubbing or polishing. The problem is that since you're starting with FLAT, and I assume you desire the car to be FLAT, in all likely hood you will be polishing the surface to some degree and 'adding' gloss. You can test in an inconspicuous area...but then again what do you have to loose?
[Re: sreinheimer]
#120986
09/17/08 05:39 PM
09/17/08 05:39 PM
sreinheimer
Winnipeg, MB
I tried polishing the paint and it turned out worse than the rest of the paint. What if i wet sand it with 3000 or 4000 and leave it would that work? Any more ideas?
05 Dodge Magnum R/T
[Re: 79powerwagon]
#120989
09/17/08 08:04 PM
09/17/08 08:04 PM
Pacnorthcuda
Isn't the preferred method to use base/clear, and add flattener to the clear?
The flat black on my Charger looks like hell, and there is no way I'd re-do the car that way (I didn't paint it that way).
Either way has been done with success--just look at our organisol. The flattening agents can be used in single stage or base clear. I would, if I were the original poster, and if I got to the point of squirting moore paint on this situation, consider the option of using a flattened clear....but he's not at that point of desperation yet.
