WTB e-body disc brake proportioning valves
#120922
09/15/08 10:52 AM
09/15/08 10:52 AM
Posts: 4,051 Connecticut
jeff968
Connecticut
I had my e-body disc brake propotioning values rebuilt but my brakes have a air leak and I believe it is coming from the PV. Fortunately, I see the repos are out now. Can anyone suggest where to purchase them? I see in-line tube sells them. Thanks
1970 Dodge Challenger T/A
Re: WTB e-body disc brake proportioning valves
[Re: 6pkaar]
#120924
09/15/08 02:33 PM
09/15/08 02:33 PM
jeff968
Connecticut
I found it and bid. Thanks
[Re: THESHAKERPROJECT]
#120930
09/16/08 03:08 PM
09/16/08 03:08 PM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
Be very careful to check the repro valve if you get one as some have a incorrect top piston that will lock your brakes and not release them. There is only one MFG of the valves but they are sold by everyone. You can check a repro by trying to blow air through the top with the top fitting tight. If it does not pass air it is a no go. I got one of the first runs so it may be corrected by now but check it to be sure. The fix ? You can use the original top piston in the reproduction valve and it will function properly. If you get a new one get it from Fine Lines. They have done further refining on this part to make it look more original and function correctly. I talked to the owner of Fine Lines at Carlisle about the defective valves ....he said that they would work with the Mfg to fix the problem.
Actually, there are two different MFG's for the ebody disc brake valve, one is Inline Tube and the other from Fine Lines. Call Billy directly 330-335-5000 x19. I have 5 Cudas with nothing but Fine Lines product on them.
#120933
09/17/08 11:24 AM
09/17/08 11:24 AM
HEMICUDA
Medina, Ohio
They are NOT made by Fine Lines or Inline Tube. The one I got was from First source performance, a e-bay reseller and it was the same part that FineLine and Inline had at Calsile as well as Mega parts and many others. They are made by one MFG and sold by many resellers. The one on display at Carsile in the Fine Lines booth was the same defective one I had from First Source. I had the owner of Fine Lines test it himself and he was suprised and said he would call the MFG and have the problem fixed. The ones with the bad piston in the pic above is for a 71-72 e-body or b-body. They may be fixed by now but many were sold befor they knew about the problem.
Actually that's not correct, there is two different manufactures of the disc brake valve, only one for the drum brake valve.
I would call Bob Groser (owner of Fine Lines) and he can explain the whole deal to you.
#120934
09/17/08 02:10 PM
09/17/08 02:10 PM
I emailed Inline Tube with a reference to this thread. Here is their response... If this problem exists with our valves, we have yet to hear it. We have sold hundreds of these to our customers as well as to may other vendors on the market. We would like to hear if our valves are having problems so that we can address it but this has not been the case. Inline Tube does manufacture our own valves. There are others that are now making this valve, so perhaps the issue is with there's. An easy way to tell if the valves are an Inline Tube product is by the INL that is stamped into every one of or valves with the exception of the front 3 port hold off valve. The 2 part valve that is being sold on Ebay and by other vendors is not an Inline Tube product, it is made by MBM. I tried to register on that board so that I could address this, but the board is not accepting new registrations at this time. If you are a registered user on this board, we would greatly appreciate you posting our response there. We have also opened some of our valves and tried what one of the posters said and there is not problem with our valves. Thank you Marc McGrew Inline Tube Sales Manager 586-532-1338 Ext 206 586-532-1339 Fax info@inlinetube.comsales@inlinetube.com
#120935
09/19/08 09:03 AM
09/19/08 09:03 AM
jeff968
Connecticut
It is a shame to think someone would design and release a product that is defective, especially with the braking system. Thanks for the heads up.
[Re: Anonymous]
#1934613
10/19/15 01:31 AM
10/19/15 01:31 AM
Posts: 380 Mesa, Az
GETX
Mesa, Az
I emailed Inline Tube with a reference to this thread. Here is their response... If this problem exists with our valves, we have yet to hear it. We have sold hundreds of these to our customers as well as to may other vendors on the market. We would like to hear if our valves are having problems so that we can address it but this has not been the case. Inline Tube does manufacture our own valves. There are others that are now making this valve, so perhaps the issue is with there's. An easy way to tell if the valves are an Inline Tube product is by the INL that is stamped into every one of or valves with the exception of the front 3 port hold off valve. The 2 part valve that is being sold on Ebay and by other vendors is not an Inline Tube product, it is made by MBM. I tried to register on that board so that I could address this, but the board is not accepting new registrations at this time. If you are a registered user on this board, we would greatly appreciate you posting our response there. We have also opened some of our valves and tried what one of the posters said and there is not problem with our valves. Thank you Marc McGrew Inline Tube Sales Manager 586-532-1338 Ext 206 586-532-1339 Fax info@inlinetube.comsales@inlinetube.com I realize that this is a very old post/thread, but I was curious if anyone can give an update on this subject? Do the Inline Tube Prop Valves work as the originals ? I know that Fine Lines no longer sell these Prop Valves.
[Re: GETX]
#1935026
10/19/15 05:12 PM
10/19/15 05:12 PM
Posts: 755 Tempe, AZ
loco340cuda
Tempe, AZ
Not to high jack this thread, but does anyone do rebuilds on the originals?
70 Cuda 340 4 speed - now stroked to 416ci (SOLD) 2017 Mustang Shelby GT350
[Re: jeff968]
#1935887
10/20/15 11:24 PM
10/20/15 11:24 PM
loco340cuda
Tempe, AZ
BTT, so does anyone know if anyone rebuilds the originals as well as do the inline repo's work as good as the originals?
#1941185
10/29/15 07:04 PM
10/29/15 07:04 PM
Posts: 1,232 Chicago, IL
PLUM_72
Chicago, IL
See the attached photo, while it shows the 1972 proportioning valves, the valves from other cars, vans or trucks may work in all but the most perfect restos.
1972 Dodge Challenger
