I have a LD4B that I run on 360 heads and on the #302 heads.
I have run many stock cast iron intakes on small port 318 heads with q-jets.
you wont notice any mis-match in the ports with street duty.
tune the q-jet properly and it will make a 318 buzz right up there.
running the stock 88 cast iron intake with a 74 chebby q-jet.mopar throttle lever tac weld on to it on the 91 JY 318 with the voodoo roller cam in the 85 truck now.
biggest thing I had to do moveing it from 360 heads to the #302 heads was adjust the airdoor on the back of the q-jet and pull timeing out of it compaired to what the 360 headed 318 wanted.
IMHO,thats due to the fast burn,swirl port of the closed chamber #302 head.
it flat out rocked with the LD4B and 600 eddy carb,but got 15 mpg and the q-jet is knocking back 19 mpg
the 81 kawasaki kz 550 I just bought gets 65 mpg
