340 6 pack build #1209009
04/03/12 12:07 PM
04/03/12 12:07 PM
walton ny
W
woody30 Offline OP
woody30  Offline OP
W
walton ny
Hey guys, hello and great to be here. Anybody got a really really good running 340 6 pack car?? I have a 67 Barracuda that I'm restoring with a 4 speed and 8 3/4 3.91 posi rear. Bought a 69 340 for it. Has had the stock forged crank turned .010 on rods and mains, has stock x heads, .030 10:1 pistons, and I bought a 6 pack set up for it. Pretty well set except for the cam. I want a strong street/strip set up so the right cam is imperative. Of course I want the best of both worlds streetability and big power. It has to whip my son's 1980 z28 Camaro (he has run 13.00 and 106 mph at the strip). Talked to the Comp Cams tech and he recommended an xtreme energy 274/286 duration .488/.491 lift cam. Seems a little small for that induction set up. Or is he being conservative because of the street issuses with a big cam? Any ideas???? Thanks, Woody
Re: 340 6 pack build [Re: woody30] #1209010
04/03/12 01:28 PM
04/03/12 01:28 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
If your going to run a cam that is that big you better think about a 4bbl instead of the 6 pack.
You need vacuum to operate the end carb properly.
Im running a 340-6 in my 81 shorty with a OD833 and 3.91s.
I have 268/272/.450/.455 MP Purple cam and performes real well with the ^ pack..
I am truckless..
Re: 340 6 pack build [Re: woody30] #1209011
04/03/12 02:16 PM
04/03/12 02:16 PM
I have help tune and owned a bunch of six pak motors with larger cams than that I'm a comp Cams dealer also, PM me if you want a good deal on a new cam and lifters I would use the XR292HR-10 in your car or a similar grind if you want a stock type hydraulic lifters and cam BTW, you will neeed adjustable rockers and the proper pushrods with the bigger cams like those My street Duster has a Comp Cams custom grind solid roller that is 260 degrees at .050 with .700 net lift, the motor is a pum gas 518 C.I. low deck stroker with a six pak, it has ran 10.43 ET at 128.+ MPH on pump gas with the air cleaner and mufflers on Mopar sixpaks rule, BB or SB
Re: 340 6 pack build [Re: 340SHORTY] #1209012
04/03/12 02:26 PM
04/03/12 02:26 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what? I'm running a 588 solid roller cam w a factory 6-pack. Anyway, that should run pretty good. You might need a little more cam. The trcik will be getting out of the hole w/ the 4 speed. I'd spend a few dollars and get the heads cleaned up..at least do some home porting.
Good luck
Coming soon!!!!
Re: 340 6 pack build [Re: Mr.Yuck] #1209013
04/03/12 03:46 PM
04/03/12 03:46 PM
walton ny
W
woody30 Offline OP
woody30  Offline OP
W
walton ny
Thanks for the food fellas. Yeah, I know those x heads are old school. Never ported anything before but I'm not afraid. Saw an article in Mopar Muscle where they put a comp xtreme energy 268 cam in a 340 with stock x heads, air gap intake, 800 carb and 1 5/8 tube headers and made 392 hp. Not bad with 40 year old stock heads. A little porting and the 6 pack she should go 425 hp or so I would guess.
Re: 340 6 pack build [Re: woody30] #1209014
04/03/12 03:58 PM
04/03/12 03:58 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Last 340 6 pack I built used a 275hl comp with ebrocks. I was more concerned about power than the cust was,, but he came out very happy.
(still couldn't convince him to dump the six pack )
Re: 340 6 pack build [Re: woody30] #1209015
04/04/12 01:55 AM
04/04/12 01:55 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
old schol here , i would use eather the mopar 280-474 hyd or the mopar 284-528 solid !
eather cam should put your car in the 12 sec range !
Re: 340 6 pack build [Re: calrobb2000] #1209016
04/04/12 03:19 AM
04/04/12 03:19 AM
southern California
1970sixpak Offline
1970sixpak  Offline
southern California
go with a roller or hydraulic roller camshaft.
Re: 340 6 pack build [Re: 1970sixpak] #1209017
04/04/12 09:09 AM
04/04/12 09:09 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
plenty of new profiles out there that have nice driving manners and great performance. Solid or hydro...
Re: 340 6 pack build [Re: woody30] #1209018
04/04/12 12:05 PM
04/04/12 12:05 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Welcome to Moparts, Woody!
You've come to the right place to get your 340 dialed in.
Feel free to post a pic of your car and your son's Z28.
Mo' Farts
Moderated by "tbagger".
Re: 340 6 pack build [Re: Grizzly] #1209019
04/04/12 12:12 PM
04/04/12 12:12 PM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
I built a 340 six pack a year ago. However, I used a 1199$ 4" stroker kit. It had a comp cams 285XE cam and was externally completely stock. Made 410 hp through the stock manifolds and exhaust, and 440 hp with 1 5/8 primary headers. Should have run 13's without any effort.
Plynouth VIP '67 TT IC EFI
