Re: 340 6 pack build
[Re: woody30]
#1209010
04/03/12 01:28 PM
04/03/12 01:28 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
If your going to run a cam that is that big you better think about a 4bbl instead of the 6 pack. You need vacuum to operate the end carb properly. Im running a 340-6 in my 81 shorty with a OD833 and 3.91s. I have 268/272/.450/.455 MP Purple cam and performes real well with the ^ pack..
I am truckless..
[Re: woody30]
#1209011
04/03/12 02:16 PM
04/03/12 02:16 PM
Posts: 43,180 Bend,OR USA
Cab_Burge
I have help tune and owned a bunch of six pak motors with larger cams than that I'm a comp Cams dealer also, PM me if you want a good deal on a new cam and lifters I would use the XR292HR-10 in your car or a similar grind if you want a stock type hydraulic lifters and cam BTW, you will neeed adjustable rockers and the proper pushrods with the bigger cams like those My street Duster has a Comp Cams custom grind solid roller that is 260 degrees at .050 with .700 net lift, the motor is a pum gas 518 C.I. low deck stroker with a six pak, it has ran 10.43 ET at 128.+ MPH on pump gas with the air cleaner and mufflers on Mopar sixpaks rule, BB or SB
[Re: 340SHORTY]
#1209012
04/03/12 02:26 PM
04/03/12 02:26 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
what? I'm running a 588 solid roller cam w a factory 6-pack. Anyway, that should run pretty good. You might need a little more cam. The trcik will be getting out of the hole w/ the 4 speed. I'd spend a few dollars and get the heads cleaned up..at least do some home porting. Good luck
[Re: woody30]
#1209015
04/04/12 01:55 AM
04/04/12 01:55 AM
Posts: 1,997 s. e. pa.
calrobb2000
s. e. pa.
hi old schol here , i would use eather the mopar 280-474 hyd or the mopar 284-528 solid ! eather cam should put your car in the 12 sec range !
[Re: woody30]
#1209018
04/04/12 12:05 PM
04/04/12 12:05 PM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
Welcome to Moparts, Woody! You've come to the right place to get your 340 dialed in. Feel free to post a pic of your car and your son's Z28.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#1209019
04/04/12 12:12 PM
04/04/12 12:12 PM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
I built a 340 six pack a year ago. However, I used a 1199$ 4" stroker kit. It had a comp cams 285XE cam and was externally completely stock. Made 410 hp through the stock manifolds and exhaust, and 440 hp with 1 5/8 primary headers. Should have run 13's without any effort.
Plynouth VIP '67 TT IC EFI
