Console Top Plate Woodgrain Sticker Install #120891
09/15/08 07:21 AM
09/15/08 07:21 AM
Anonymous OP
Anonymous OP
Any special technique to this? What if it needs to be readjusted when installing? I thought I read on here awhile back that you spray some water down first, so it slides around until it's in exactly the right position. Is that right?
Re: Console Top Plate Woodgrain Sticker Install #120892
09/15/08 07:26 AM
09/15/08 07:26 AM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
You can use water with a tiny drop of soap or Windex....
For a console I would most likely center it around the shifter hole first
CHECK OUT MY NEW WEB SITE !
Re: Console Top Plate Woodgrain Sticker Install #120893
09/15/08 07:28 AM
09/15/08 07:28 AM
Burma Shave
plymouthfan Offline
plymouthfan  Offline
Burma Shave
Craig, If it's anything like adding a stripe decal, then yes, you spray on a light coat of water with a drop or two of dish soap added. I think I added it to both the surface and the decal. Get it where you want it then burnish the water out
One red car, one yellow car.
Re: Console Top Plate Woodgrain Sticker Install [Re: plymouthfan] #120894
09/15/08 10:24 AM
09/15/08 10:24 AM
MoreParts Offline
MoreParts  Offline
Wait a sec. These are stickers aren't they? I haven't seen any that were decals unless that's a new thing.
Re: Console Top Plate Woodgrain Sticker Install [Re: MoreParts] #120895
09/15/08 02:48 PM
09/15/08 02:48 PM
Anonymous OP
Anonymous OP
Yes, it's sticky on the mating surface. Does that matter when using water to apply?
Re: Console Top Plate Woodgrain Sticker Install #120896
09/15/08 03:12 PM
09/15/08 03:12 PM
anlauto Offline
anlauto  Offline
Tomato/tomAto
Decals/stickers = same thing to some people...no problem using water...
Re: Console Top Plate Woodgrain Sticker Install [Re: anlauto] #120897
09/15/08 03:56 PM
09/15/08 03:56 PM
Anonymous OP
Anonymous OP
Thanks everyone!!!
