Console Top Plate Woodgrain Sticker Install
#120891
09/15/08 07:21 AM
09/15/08 07:21 AM
Any special technique to this? What if it needs to be readjusted when installing? I thought I read on here awhile back that you spray some water down first, so it slides around until it's in exactly the right position. Is that right?
Re: Console Top Plate Woodgrain Sticker Install
#120892
09/15/08 07:26 AM
09/15/08 07:26 AM
Posts: 11,854 Georgetown Ontario Canada
anlauto
You can use water with a tiny drop of soap or Windex.... For a console I would most likely center it around the shifter hole first
CHECK OUT MY NEW WEB SITE !
[Re: MoreParts]
#120895
09/15/08 02:48 PM
09/15/08 02:48 PM
Wait a sec. These are stickers aren't they? I haven't seen any that were decals unless that's a new thing.
Yes, it's sticky on the mating surface. Does that matter when using water to apply?
[Re: anlauto]
#120897
09/15/08 03:56 PM
09/15/08 03:56 PM
