Re: Best value / most effective balancers?
[Re: Moparmal]
#1208956
04/03/12 07:26 AM
04/03/12 07:26 AM
Posts: 553 Kentucky
clovis
Kentucky
Not sure if they make one for a small block but the Powerbond balancers are a good value. You can actually get them through Amazon.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
[Re: Moparmal]
#1208957
04/03/12 09:03 AM
04/03/12 09:03 AM
Posts: 855 Brisbane Australia
572B1
Brisbane Australia
I've often wondered how you pick a good balancer from a bad one.......
So what are the best value and best brand balancers for LA small blocks?
Is there much difference between a Professional Plroducts and a Fluid Damper?
Whats wrong with a Romac balancer.
[Re: 572B1]
#1208959
04/03/12 09:12 PM
04/03/12 09:12 PM
Posts: 7,506 Az
Crizila
Az
I'm going with a "fluid Damper" on my 408 blower motor. Had it cut with a second keyway ( 1/4" )@ 180 degrees from the standard 3/16" keyway. Crank snout of course too. Fluid style dampers are the best in the business IMO - but expensive!!!
Fastest 300
[Re: Crizila]
#1208960
04/03/12 09:14 PM
04/03/12 09:14 PM
Posts: 12,396 Taxes & Virus's R-US, NY
Dragula
ATI!
Ask the guys at Fluid Damper what harmonic it dampens at 50*F and what harmonics its dampening at 90*F...All I got was dead silence. Seems to me, we race at different temps, and the damper can't be dampening the same throughout the normal range of temps I am sure...Not to mention, the tech on the phone didn't dispute that. Sorry, but I believe the harmonics to an engine don't change with temperature...why should the damper change. I went with ATI, and it has been awesome.
[Re: Dragula]
#1208961
04/03/12 09:27 PM
04/03/12 09:27 PM
Posts: 7,506 Az
Crizila
Az
Well, most airplane engines run fluid filled dampers. Assume the temp swings are much greater than ours. Have no clue what fluid is used, but it must have a pretty stable viscosity over a wide temp range. Fluid dampers rank pretty high on most blower motor builders lists.
Fastest 300
[Re: clovis]
#1208963
04/03/12 10:52 PM
04/03/12 10:52 PM
Posts: 914 tn
robnbird
tn
thank you Clovas for the quote, we need the word.
[Re: Moparmal]
#1208964
04/03/12 10:55 PM
04/03/12 10:55 PM
Posts: 914 tn
robnbird
tn
I use the Romac sfi 17000 the best in my openion for the money
[Re: Dartin]
#1208969
04/04/12 08:30 AM
04/04/12 08:30 AM
Challenger 1
Cincinnati, Ohio
I've learned from experience that you get what you pay for. I bought a Summit SFI balancer and used it successfully for about 3 years (under 100 passes and 200 street miles). I tried to re-use it on my new 540. While we had it on the dyno, the outer ring was slipping pretty badly. ATI is what I will use now.
Randy
ATI is the best value, imo.
[Re: Scamp408]
#1208970
04/04/12 07:14 PM
04/04/12 07:14 PM
Posts: 4,209 New York
polyspheric
New York
WW2 aircraft engines: 1. radial, low RPM (B29, P47) 2. V12 in-line, low RPM (P51 with Rolls engine: 6" stroke) and has inherent primary balance (same as in-line 6)
Boffin Emeritus
[Re: dogdays]
#1208972
04/04/12 07:28 PM
04/04/12 07:28 PM
Posts: 293 Kansas City Metro
mbogina
Kansas City Metro
I am biased to the ATI. We did some testing for ATI when they were under development. We also looked at about 10 different possibilities for proper dampening before finding the ATI style. One of the most effective we tried was a damper shell filled w lead shot- very effective but the ability to dampen diminished as the lead shot became deformed over time. In our testing, the fluid style was the worst we looked at, the floating weight would sometimes end up exactly 180 deg from where it should be, which led to broken cranks from inbalance, not from the lack of dampening. The TCI Rattler style is also a very effective dampener.
Be a Rebel- Break the Laws of Physics!
