A Body KH Brake issues-need suggestions #1208711
04/02/12 10:55 PM
04/02/12 10:55 PM
NE Texas
JoeDragster Offline OP
NE Texas
I bought a 71 Demon, 318 car with 7 1/4 and drum brakes recently and without asking alot of questions, installed a set of front KH brakes. I did not change the master cylinder and prop brake. The brakes work but not very good and the pedal is very hard and the car does not stop wac.
Besides the mistake of not changing the MC and Prop valve, is there any other issues i have created?
What is the easiest way to change the prop valve
ideas and suggestions welcome.
Re: A Body KH Brake issues-need suggestions [Re: JoeDragster] #1208712
04/02/12 10:57 PM
04/02/12 10:57 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Drum brakes have a different master , you need to change both the master cylinder and the prop valve.
Re: A Body KH Brake issues-need suggestions [Re: JohnRR] #1208713
04/02/12 11:17 PM
04/02/12 11:17 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
What John said, or add the M/C and an aftermarket adjustable proportioning valve.
Re: A Body KH Brake issues-need suggestions [Re: JoeDragster] #1208714
04/03/12 12:14 AM
04/03/12 12:14 AM
No proporting valves on drum brake cars, only came on disc brake front with drum brake rear cars As already pointed out the disc brake cars neeed a disc brake M.C. with no residual valve on the disc brake reservior Your dragging the disc with the residual valve and you need the proper size master cylinder bore size
Re: A Body KH Brake issues-need suggestions [Re: Cab_Burge] #1208715
04/03/12 10:09 PM
04/03/12 10:09 PM
NE Texas
NE Texas
thanks for the reply, is there any tips for installing the disk brake Prop valve. I picked up one and it looks awful tight in there to get any wrenches to loosen the brake lines. any suggestions appreciated.
Re: A Body KH Brake issues-need suggestions [Re: ScottSmith_Harms] #1208716
04/03/12 10:12 PM
04/03/12 10:12 PM
NE Texas
NE Texas
thanks for the reply, i picked up a factory disk brake prop valve from a buddy of mine. how in the heck can you remove the old piece? it is full of stuff in the way
