4 speed pilot bushing lubrication #1208627
04/02/12 10:05 PM
04/02/12 10:05 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
I soaked my pilot bushing in oil prior to installing it. Is there any other lubrication I should employ prior to installing gearbox?
Re: 4 speed pilot bushing lubrication [Re: 70mopes] #1208628
04/02/12 10:07 PM
04/02/12 10:07 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Sure, anything you want to get on your clutch disc. Tim
Re: 4 speed pilot bushing lubrication [Re: astjp2] #1208629
04/02/12 10:37 PM
04/02/12 10:37 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
I am aware of where excess can end up. Just wondering if an oil soaked bushing is sufficient or if there is any additional tried and true method.
Re: 4 speed pilot bushing lubrication [Re: 70mopes] #1208630
04/02/12 10:49 PM
04/02/12 10:49 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Never heard of of soaking the bushing ? I just put it together with the slightest dab of antiseize , most of the time the 2 parts are locked together .
Re: 4 speed pilot bushing lubrication [Re: JohnRR] #1208631
04/02/12 11:23 PM
04/02/12 11:23 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
Thanks for both responses John. I think my old shop teacher in high school taught me the soaking in oil trick. Bronze is very pourous and will capture and retain oil.
Re: 4 speed pilot bushing lubrication [Re: 70mopes] #1208632
04/02/12 11:53 PM
04/02/12 11:53 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
This is what I do, too.
It's Swifty! Swifty, you toad sucker!
Re: 4 speed pilot bushing lubrication [Re: 70mopes] #1208633
04/03/12 12:00 AM
04/03/12 12:00 AM
Cab_Burge Online work
Cab_Burge  Online Work
Chevys need soaking , Lubrite Mopar pilot bushing do not, according to all the Mopar factory service manuals from the late 1960 and early 1970s that I have. The bushing are refferred to as Lubrite
Re: 4 speed pilot bushing lubrication [Re: Cab_Burge] #1208634
04/04/12 12:01 AM
04/04/12 12:01 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I use wheel bearing grease. A tiny bit flinging off onto the clutch has never caused an issue for me.
Re: 4 speed pilot bushing lubrication [Re: Magnum] #1208635
04/04/12 12:43 PM
04/04/12 12:43 PM
dogdays Offline
dogdays  Offline
Guys, Guys, Guys!
Pilot bushings are made of oil-impregnated sintered bronze. It was invented by Chrysler engineers. It does NOT need anything done to it to run.
I have never heard of soaking a pilot bushing, your old shop teacher was misguided.
As for bronze, all of the bronze I have used, and I have specified and used a lot of bronze in industrial applications, IS NOT POROUS. Bronze valves hold pressure through the bodies just like cast iron or steel.
Sintered bronze bushings start their life as coarse grained powder that is pressed into a shape, then baked or sintered. The bushing is then impregnated with lubricant. It needs no further lubrication. When you change your clutch, change the bushing at the same time. That's why it's in the clutch kit.
R.
Re: 4 speed pilot bushing lubrication [Re: Magnum] #1208636
04/04/12 12:51 PM
04/04/12 12:51 PM
IMGTX Offline
IMGTX  Offline
Me too. Don't pack it in there, just swipe it on.
Re: 4 speed pilot bushing lubrication [Re: 70mopes] #1208637
04/04/12 02:24 PM
04/04/12 02:24 PM
AndyF Offline
AndyF  Offline
This is one of those situations where it actually is a good idea to open up the service manual and to follow the instructions.
Re: 4 speed pilot bushing lubrication [Re: AndyF] #1208638
04/04/12 04:03 PM
04/04/12 04:03 PM
WHY NOT
Re: 4 speed pilot bushing lubrication [Re: dogdays] #1208639
04/04/12 04:23 PM
04/04/12 04:23 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
Guys, Guys, Guys!
R.
Exactly as stated.
