Indy 360 heads and offset lifters??
#1208454
04/02/12 07:32 PM
04/02/12 07:32 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Before I order my solid roller lifters thought I would ask if I should run an offset lifter with my 360-1 cnc heads??? Thought it might be a good idea to help straighten out the pushrod angle to the rockers as they are offset also(1.7 ratio T&D shaft rockers) they are also pushrod oiling.
DEPUTY
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
