who has used the scarebird disc brake conversion? #120836
09/15/08 12:10 AM
09/15/08 12:10 AM
Eugene, OR
FuryBoy Offline OP
FuryBoy  Offline OP
Eugene, OR
I have a set of scarebird disk brake conversion brackets for my '70 Challenger. I am wondering who has done this swap, what calipers and brake hoses they are using and if they are running a sway bar and gas shocks.
I bought these brackets, but I am having second thoughts and I'm thinking MP '73-'76 A body reproductions may be the way to go...
Re: who has used the scarebird disc brake conversion? [Re: FuryBoy] #120837
09/15/08 09:06 AM
09/15/08 09:06 AM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
I used the scarebird setup, but on an A-body..
Re: who has used the scarebird disc brake conversion? [Re: Dakota_Don] #120838
09/15/08 09:14 AM
09/15/08 09:14 AM
Eugene, OR
FuryBoy Offline OP
FuryBoy  Offline OP
Eugene, OR
which calipers did you use? did you swap spindles left to right?
Re: who has used the scarebird disc brake conversion? [Re: FuryBoy] #120839
09/15/08 10:08 AM
09/15/08 10:08 AM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
i used celbrity calipers..
Re: who has used the scarebird disc brake conversion? [Re: Dakota_Don] #120840
09/15/08 11:39 PM
09/15/08 11:39 PM
Eugene, OR
FuryBoy Offline OP
FuryBoy  Offline OP
Eugene, OR
no one else?
Re: who has used the scarebird disc brake conversion? [Re: FuryBoy] #120841
09/16/08 12:21 PM
09/16/08 12:21 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
I used a scarebird conv. on my 67 b-body...worked like a charm,no problems..the instructions w/ my kit had me use (god..i hate to say this)cheby truck calipers,eldorado brake hoses,and mid-70's grand fury hub/rotor..i was sceptic at first,but everything fit fine..
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: who has used the scarebird disc brake conversion? [Re: racerAL] #120842
09/16/08 02:25 PM
09/16/08 02:25 PM
Haysville, Kansas
rdrmod6 Offline
rdrmod6  Offline
Haysville, Kansas
I used one on my 64 the brackets fit fine. For the brake hoses I bought fittings from AFCO and braided steel lines. once I replaced the bump stop for the upper control arms it was fine
Re: who has used the scarebird disc brake conversion? [Re: racerAL] #120843
09/16/08 02:57 PM
09/16/08 02:57 PM
SW MO
closer9 Offline
closer9  Offline
SW MO
I've got this same setup on my '67 b-body, and wasn't impressed.
I had to machine the plates to fit around the lower ball joint, had to have some spacers made for the oil seals to fit into the fury rotors once their bearing spacer was in place, and I am now using the recommended 70 b-body MC that doesn't seem to have enough capacity to work the truck calipers... My car hasn't been driven in almost 2 years now, but I'm hoping to get it back in my garage soon, and get this worked out...
I REALLY wish I had just used the 5th Ave discs I had planned on using...
racerAL, what master cylinder are you using?
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
Re: who has used the scarebird disc brake conversion? [Re: closer9] #120844
09/16/08 04:12 PM
09/16/08 04:12 PM
Eugene, OR
FuryBoy Offline OP
FuryBoy  Offline OP
Eugene, OR
This really concerns me, but I would need some '73-'76 Dart spindles(can't find any around here) to run regular mopar calipers...
I really don't want to open the whole F/J/M body spindle debate here, cause I'd rather not use those.
I was planning on running Crown braided brake lines if I couldn't find a decent set up...
What chevy pick up calipers? just 2 wheel drive 1/2 tons?
I was thinking a chevelle or Transam caliper myself...
Re: who has used the scarebird disc brake conversion? [Re: FuryBoy] #120845
09/16/08 04:15 PM
09/16/08 04:15 PM
SW MO
closer9 Offline
closer9  Offline
SW MO
I'm pretty sure the kits use different parts now, but mine used 90's 2wd GM truck calipers...
Daily:
'19 Frontier 4WD
Belle:
Other:
Re: who has used the scarebird disc brake conversion? [Re: closer9] #120846
09/16/08 09:29 PM
09/16/08 09:29 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
I had to machine the plates to fit around the lower ball joint, had to have some spacers made for the oil seals to fit into the fury rotors once their bearing spacer was in place.
....I
am using a mid 80's reliant/k-car master cylinder.it resembles the MP piece but half the $.as a matter of fact i'am using the MP adapter.it fits perfect.i also use a in-line adjustable porpotioning (sp) valve,i can adjust the front and rear brake ballast.i'am not sure about how well this would work on the street ...but i have had NO problems stopping my 3400# car from the mid-11's at 120 or so..Also, i looked at my instr. sheet that came with the kit,and closer9 was correct.they had changed the kits.my kit came with the spacers and had been changed for ball joint fit,and also used mid 90's chevy truck calipers(2wd).
446 cid on E-85
best 60ft. 1.419
Re: who has used the scarebird disc brake conversion? [Re: racerAL] #120847
09/16/08 09:53 PM
09/16/08 09:53 PM
SW MO
closer9 Offline
closer9  Offline
SW MO
....I
Thanks!
I'll look into that MC and the MP adapter. That may make all the difference...
Daily:
'19 Frontier 4WD
Belle:
Other:
Re: who has used the scarebird disc brake conversion? [Re: FuryBoy] #120848
09/17/08 08:44 AM
09/17/08 08:44 AM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
heres my A-body
Re: who has used the scarebird disc brake conversion? [Re: closer9] #120849
09/17/08 08:46 AM
09/17/08 08:46 AM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
....I
Thanks!
I was always told not to use FWD MC.. how did yours work out?
Re: who has used the scarebird disc brake conversion? [Re: Dakota_Don] #120850
09/17/08 12:30 PM
09/17/08 12:30 PM
SW MO
closer9 Offline
closer9  Offline
SW MO
....I
Thanks!
Why not?
BTW, I have a SSBC in-line prop-valve in the rear line.
Daily:
'19 Frontier 4WD
Belle:
Other:
Re: who has used the scarebird disc brake conversion? [Re: closer9] #120851
09/17/08 09:32 PM
09/17/08 09:32 PM
moparx Offline
moparx  Offline
the "k" master doesn't have a provision for the rubber retaining ring for a manual pushrod ? or maybe not enough stroke ? this is interesting, as speedway motors sells a "chrysler style" master with an 11/16" bore for "disc conversion kits". i think this may be a "k" master.
Re: who has used the scarebird disc brake conversion? [Re: moparx] #120852
09/17/08 09:51 PM
09/17/08 09:51 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Looks like a typo. I bet the master from Speedway Motors is a common 1 1/16" bore unit.
Re: who has used the scarebird disc brake conversion? [Re: DoctorDiff] #120853
09/18/08 09:18 PM
09/18/08 09:18 PM
moparx Offline
moparx  Offline
you mite be right doc. i never thought about a typo.....11/16 IS kinda small. i looked up the k masters in my wagner book and they list 7/8,21mm [.8268], or 24mm [.9449], depending on year and model.
