Fuel vapor Seperator #1208383
04/02/12 05:22 PM
04/02/12 05:22 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
383 Cuda. I have 3/8" main fuel line and 5/16" return line installed. Is there an affordable substitute for this seperator and is this considered the filter also or must you run a seperate one? I know these were run in the 440 HP, but it gets pretty hot done here in Florida
Grandma always said I had "hands of gold"!
Re: Fuel vapor Seperator [Re: CHRGR69] #1208384
04/02/12 06:13 PM
04/02/12 06:13 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the factory style vapor seperator is a filter too. it takes a 1/4" return.
Re: Fuel vapor Seperator [Re: lewtot184] #1208385
04/02/12 06:16 PM
04/02/12 06:16 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Correct, I meant 1/4".
Re: Fuel vapor Seperator [Re: CHRGR69] #1208386
04/04/12 10:17 AM
04/04/12 10:17 AM
Franklin Co. Illinois
runinonmt Offline
runinonmt  Offline
NAPA Gold- 3/8 line – 3041 return line goes to the top.
Make sure the hole in the return line is the same as the original. I used a Wix and it lowered my fuel pressure
Ron
Re: Fuel vapor Seperator [Re: runinonmt] #1208387
04/04/12 02:03 PM
04/04/12 02:03 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
The replacements actually have the return on the opposite end. Factory return was on the inlet (bottom) side. Aftermarket is on the outlet (top) side.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
