Anyone ever use a DUI ignition? #1207764
04/01/12 08:58 PM
04/01/12 08:58 PM
Chicken coop
dustergirl340 Offline OP
Chicken Little
Chicken Little
Chicken coop
(Davis Unified Ignition) in their small-block Mopar? What do you think of it? How does it run?
thanks
Re: Anyone ever use a DUI ignition? [Re: dustergirl340] #1207765
04/02/12 10:08 PM
04/02/12 10:08 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
We used one in a small block Chevy in a asphalt stock car. It worked great
Re: Anyone ever use a DUI ignition? [Re: dustergirl340] #1207766
04/02/12 11:39 PM
04/02/12 11:39 PM
Keizer, Oregon
Dadrules Offline
Dadrules  Offline
Keizer, Oregon
put one in a 66 200 c.i. 6 cyl mustang and the difference was shocking. it was huge tho compared to the block and looked out of place. worked very well but it looked strange when you popped the hood.
Re: Anyone ever use a DUI ignition? [Re: Dadrules] #1207767
04/03/12 12:09 AM
04/03/12 12:09 AM
IN
ahy Offline
ahy  Offline
IN
No but considered it for a non-MOPAR project. Don't plan to use it 1) because total advance (mechanical + vacuum) isn't enough for that application 2) The GM ignition module it uses is considered robust if mounted on a heat sink. The distributor does not make a very good heat sink... so maybe not so robust for sustained use.
Re: Anyone ever use a DUI ignition? [Re: ahy] #1207768
04/03/12 12:20 AM
04/03/12 12:20 AM
What's wrong with using an electronic Mopar distributor to trigger an MSD 6AL or digital 6?
Smaller cap diameter and I would bet just as hot if not hotter spark.
Re: Anyone ever use a DUI ignition? #1207769
04/04/12 01:20 PM
04/04/12 01:20 PM
dogdays Offline
dogdays  Offline
Smaller cap diameter means more chance of arc-over inside the cap. There's a reason the manufacturers went to larger caps with the big plug gaps.
The GM 4-prong electronic ignition makes a pretty good long-duration spark and costs $30, way less than a new MSD6.
Of course, I am using the electronic dist. into an ebay MSD6A that I got for something like $40.
R.
Re: Anyone ever use a DUI ignition? [Re: dustergirl340] #1207770
04/04/12 01:45 PM
04/04/12 01:45 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Nope. Been sober pretty much since I finished college, you?
Re: Anyone ever use a DUI ignition? [Re: dustergirl340] #1207771
04/04/12 01:52 PM
04/04/12 01:52 PM
NE
bigtail Offline
bigtail  Offline
NE
Got one on my Bronco with 351 windsore. Mostley bought it to clean up all the DuraSpark stuff. I'm happy with it.
This page is made up completely of recycled electrons.
Re: Anyone ever use a DUI ignition? [Re: Dragula] #1207772
04/04/12 03:16 PM
04/04/12 03:16 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
ha! Yeah, I'm good too.
Thanks for the input...just wanted to get some feedback since I couldn't find a lot of "real world" info on it.
