can someone tell me how much hp this 440 has? w/blower #1207664
04/01/12 06:28 PM
04/01/12 06:28 PM
N.Y.
sixpacksteve Offline OP
N.Y.
can anyone tell me how much hp this 440 has? or around? friends car
60 over 7 1/2 pistons-
.557 cam-906 heads 1.5 ratio rockers,
671 dyer blower 6% overdriven - 2-660 holleys
Hell Hath No Fury Like Mine
Re: can someone tell me how much hp this 440 has? w/blower [Re: sixpacksteve] #1207665
04/01/12 06:56 PM
04/01/12 06:56 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
SWAG around 450 horse.
Re: can someone tell me how much hp this 440 has? w/blower [Re: sixpacksteve] #1207666
04/01/12 07:39 PM
04/01/12 07:39 PM
Cab_Burge Online work
Cab_Burge  Online Work
First, do you know how high the motor will rev to and how much boost it is making and the last thing is which type of fuel and total ignition timing? I've made over 500 HP on N/A motors with one 850 Holley doulbe pumper with 906 (iron) heads and 9.7 to 1 or less compression ratio. That motor shuld make at least 600 HP at 6000 RPM with 6 to 10 lbs of boost on pump gas Tell him to be very careful with that stock block, they are easy to blow the main webs out of them
Re: can someone tell me how much hp this 440 has? w/blower [Re: Cab_Burge] #1207667
04/01/12 07:55 PM
04/01/12 07:55 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Well, I'm sure that at some point it passes the 450HP mark, if there's been any care to match components and tune the thing. Could be a lot more, but you'd need a 1/4 mile speed to close in on a #, and even that is a factor of weather & to some extent the rest of the car.
Re: can someone tell me how much hp this 440 has? w/blower [Re: topside] #1207668
04/01/12 08:09 PM
04/01/12 08:09 PM
N.Y.
N.Y.
he bought it like a pig in a poke. was a 12.5 piston, tunnel ram motor and it seems they swaped out the pistons and put the blower on it. we went for a ride and it when he let off, it back fired and blew the header pipe off the flange.
Re: can someone tell me how much hp this 440 has? w/blower [Re: sixpacksteve] #1207669
04/01/12 08:22 PM
04/01/12 08:22 PM
buffalo, new york
0
00snake530 Offline
00snake530  Offline
buffalo, new york
used to have an almost identical combo, mine was 1:1 driven, i would say he should be in the 700hp range
70 Challenger r/t 4 speed
00 Viper gts
67 satellite pro street
03 Ferrari 360 spider
50 chevy fleetline deluxe
15 Escalade (daily)
Re: can someone tell me how much hp this 440 has? w/blower [Re: sixpacksteve] #1207670
04/01/12 08:52 PM
04/01/12 08:52 PM
Definitely need a blower cam in it.
