Difference between 68-72 and 73-76 lower control arms #1207621
04/01/12 05:44 PM
04/01/12 05:44 PM
NE Texas
JoeDragster Offline OP
NE Texas
What is the difference between the 68-72 and 73-76 lower control arms. I can see where the sway bar tabs are located in different places, but the ball what else is different?
Re: Difference between 68-72 and 73-76 lower control arms [Re: JoeDragster] #1207622
04/01/12 06:11 PM
04/01/12 06:11 PM
IMGTX Offline
IMGTX  Offline
What kind of car?
A, B, E or C?
Re: Difference between 68-72 and 73-76 lower control arms [Re: JoeDragster] #1207623
04/01/12 06:29 PM
04/01/12 06:29 PM
Rancho Cordova, California (Sa...
hemi71x Online content
hemi71x  Online Content
There is No difference in A body LCA's from 1962-76.
They are all the same.
It's where the sway bar mount tabs are welded onto the arm, if it's equipped with a sway bar.
65-72 tabs are welded onto the arm, low, near the ball joint hole.
73-76 cars have the tab welded on in the middle of the arm.
There is NO difference in the ball joint stud hole diameter, in any of the years.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Difference between 68-72 and 73-76 lower control arms [Re: hemi71x] #1207624
04/01/12 07:29 PM
04/01/12 07:29 PM
I'm almost sure the lower control arm are dfferent from 1973 to 1976 and the arlier ones, the hole for the lower ball joint stud is different. I found that out when swapping the front spindle and ball joints off of my 1971 Duster to the later 1973-76 spindle, upper and lower control arms and brakes I know many people think there the same but try fitting the 1973 and later ball joints, upper and lower, into the early arms You can ream the holes out to the larger size to make them work but they don't fit stock
Re: Difference between 68-72 and 73-76 lower control arms [Re: Cab_Burge] #1207625
04/01/12 09:18 PM
04/01/12 09:18 PM
That is not true.
You are misinformed about that, for some reason or another.
Ball joint stud hole diameters are all the same throughout all the years.
Nothing at all changed in the LCA's.
Re: Difference between 68-72 and 73-76 lower control arms [Re: hemi71x] #1207626
04/01/12 09:24 PM
04/01/12 09:24 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Differences in sway bar location for A-bodies.
73-76 is on the left of the picture
68-72 is on the right
Re: Difference between 68-72 and 73-76 lower control arms [Re: JoeDragster] #1207627
04/01/12 10:00 PM
04/01/12 10:00 PM
AndyF Offline
AndyF  Offline
Depends on the car that you are talking about.
Re: Difference between 68-72 and 73-76 lower control arms [Re: AndyF] #1207628
04/01/12 10:27 PM
04/01/12 10:27 PM
After reading this I want to clarify that the cars I was swapping parts on where a 1971 Duster with stock disc brakes, I was swapping parts from a 1973 and 1974 Duster, one of the LCA was bad on the 1973 Duster so I took one off of a 1974 to finish the job. I don't know about the drum brake spindles, ball joints or LCA IHTHs
Re: Difference between 68-72 and 73-76 lower control arms [Re: Cab_Burge] #1207629
04/01/12 11:42 PM
04/01/12 11:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Cab , the LCA are the same , what is different is the knuckles on 73 up WITH DISC BRAKES AND 10" DRUM BRAKES, they accept the larger B/E upper balljoint and the Upper control arm is different 73-76 A body.
Post deleted by moparts [Re: JohnRR] #1207630
04/02/12 01:43 AM
04/02/12 01:43 AM
Re: Difference between 68-72 and 73-76 lower control arms #1207631
04/02/12 10:46 AM
04/02/12 10:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
, what is different is the knuckles on 73 up , they accept the larger B/E upper balljoint and the Upper control arm is different 73-76 A body .
That is if the car has disc brakes or 10" drums.
There were a few cars built with 9" drums. Those still used the small upper ball joint.
I edited my post above because I neglected to include every possible brake option .
Re: Difference between 68-72 and 73-76 lower control arms #1207632
04/02/12 05:20 PM
04/02/12 05:20 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
I doubt that. Try and find more than one A body UCA in any 73-up parts book.
Post deleted by moparts [Re: nomore65BelvJim] #1207633
04/02/12 05:33 PM
04/02/12 05:33 PM
Re: Difference between 68-72 and 73-76 lower control arms #1207634
04/02/12 05:41 PM
04/02/12 05:41 PM
This issue pops up often. I wonder how many naysayers have ever cared to look under a 73-76 A body. They are not the most desireable of the A body cars, so I doubt that many that doubt the existence of a post 73 9" drum brake has ever looked very close. Don't believe everything that you read in books. I have no financial interest in convincing anyone that they were built. I just know that in 18 years of junkyard doggin' I have seen several. I OWNED a 1976 Dart with so few options, you'd think that a person ordered it as a joke to see if Chrysler would build it. Slant six, 904, 9" drums at each corner, and an AM radio. I should have kept the fender tag because it was the simplest I'd ever seen. It's odd that so many agree that Chrysler built some wierd cars but will still insist that every A body after 1972 had front disc brakes. I've read that at some point in 1976, the feds required front discs on every vehicle. THAT I'd be willing to believe, since my '76 Dart had an October build date.
If you actually read what I said I made no mention of the 9" brakes. Nor did I insist on anything about disc brakes after 72.
Your story of the 76 with "9" drums at all 4 corners" will not pass the sniff test. There were no 9" drums after 73. V8's after 73 were all disc brakes. By 1/1/1976 they were ALL large bolt pattern disc brake cars. Period.
Did you miss your PM priveledges so much you have to use another account?
Re: Difference between 68-72 and 73-76 lower control arms [Re: nomore65BelvJim] #1207635
04/02/12 06:05 PM
04/02/12 06:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That thought had crossed my mind ...
Re: Difference between 68-72 and 73-76 lower control arms [Re: JohnRR] #1207636
04/02/12 07:04 PM
04/02/12 07:04 PM
I'm sure it ricocheted around a bit on its way through
Re: Difference between 68-72 and 73-76 lower control arms [Re: nomore65BelvJim] #1207637
04/02/12 07:33 PM
04/02/12 07:33 PM
I guess i will get involved in this depate one more time about 9 inch brakes on the 73-76 A body line of cars.
For 35 years, i would have told you the same thing that no such cars ever existed.
73-76 A body's with 9 inch, small bolt pattern, brakes on them.
Within the past few months, i have come across two 74 Plymouth Valiants that had 9 inch brakes on them.
In all rights, they should have been 10 inchers, but these cars appeared never to have been wrenched on in their lives.
So until you actually see one, two, or more of them in person, it convinced me that Mopar did lots of stuff that was supposed to never be.
Re: Difference between 68-72 and 73-76 lower control arms [Re: nomore65BelvJim] #1207638
04/02/12 07:43 PM
04/02/12 07:43 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Did you miss your PM privileges so much you have to use another account?
Registration date is over a year ago, but there are similarities.
If you read this thread, you will find the following posting from a very close relative of "roof framer":
This topic still is a room divider. I've parted out several A bodies over the years and can only offer what I have seen.
Yes, there were SOME a body cars built after 1973 that had front drum brakes. SOME were 10" and used the large upper ball joint. ALL front drum brake A body cars used the small 5 on 4 bolt circle. The steering knuckle that the brakes attached to are different from the 9" to the 10" brakes. The '73-76 Disc knuckle is also different.
Over the years there has certainly been parts swapping done to these cars and I am sure that cars have been found to have "factory" parts switched to them that they never were available on that particular car. Case in point: I owned a well used up 1976 Dart Swinger that had a Slant Sick, 904 and 9" drum brakes on all 4 corners. I posted about this here and was told by many members that NO A body after 1973 came without disc brakes. THEN a few posts trickled in about...."Ahh, Maybe a few drum brake cars slipped by as Chrysler was using up their inventory....
I do not claim to be the GALEN on junkyard A bodies, I just recall what I have found. I've seen several 73-76 A body cars with front drum brakes. I will admit that many of the cars that I have seen MAY have had their original disc brakes pulled and someone MAY have swapped drums back on..... but how could that have happened so many times?
Down to just a blue car now.
Re: Difference between 68-72 and 73-76 lower control arms [Re: hemi71x] #1207639
04/02/12 10:31 PM
04/02/12 10:31 PM
NE Texas
NE Texas
I was asking about the A body but you answered the question. thanks
Re: Difference between 68-72 and 73-76 lower control arms [Re: JoeDragster] #1207640
04/02/12 10:43 PM
04/02/12 10:43 PM
NE Texas
NE Texas
I appreciate the discussion....i looked real hard on both lca from the two spreads of years. both lca ball joint holes look the same and when i tried fitting a 73-76 ball joint stud, the ball joint fit down inside the hole on both the 68-72 and 73-76. From the array of control arms i tried, some were more worn than others and sat somewhat deeper on the tapered shaft than the others. But that appeared to be a wear issue on the lca and not the balljoint stud. Like some others, i assumed that the lca ball joint studs were larger on the 73-76 A bodies and from what i see from the parts i have, that is not the case.
