slant 6 #1207366
04/01/12 08:41 AM
04/01/12 08:41 AM
Downey, IA
Gt383 Offline OP
Gt383  Offline OP
Downey, IA
Are all slant 6 engines externally balanced? Ive never seen one with a weighted converter. So all flywheel/torque converters exchange?... save for the pre-post 68 small crank pilot deal?
If I hafta come in and getchya.......I'm gonna getchya!
Re: slant 6 [Re: Gt383] #1207367
04/01/12 10:08 AM
04/01/12 10:08 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
They are all internally balanced.
All '68-up 904 non-lock up convertors will exchange with non-lock up '68-up 904s. All lock up 904 convertors will exchange with lock up 904s. Difference is 23 vs 24 spline input shaft.
Re: slant 6 [Re: B5 Bee] #1207368
04/01/12 12:55 PM
04/01/12 12:55 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
The cast crank motors (mid '76 and later) had a different looking damper on them but all are still interchangable. Slants are actually neutral balance.
Besides the crank register they did change the location of the timing tab/mark in the mid '60's too.
Re: slant 6 [Re: slantzilla] #1207369
04/01/12 01:10 PM
04/01/12 01:10 PM
so would you just have to remark the balancer if you used the different t cover w the diff tab?
Re: slant 6 [Re: RapidRobert] #1207370
04/01/12 03:21 PM
04/01/12 03:21 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Sure. Find true TDC and make a notch with a hacksaw blade or 3 point file.
Re: slant 6 [Re: slantzilla] #1207371
04/01/12 04:00 PM
04/01/12 04:00 PM
Thanks Slantzilla
Re: slant 6 [Re: RapidRobert] #1207372
04/15/12 10:02 AM
04/15/12 10:02 AM
Downey, IA
Gt383 Offline OP
Gt383  Offline OP
Downey, IA
So putting a flywheel off a 1970 slant on a 82 slant is fine? thanks fellas
