Re: Hard starting when motor is hot
[Re: Exit1965]
#120726
09/14/08 10:30 PM
09/14/08 10:30 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
23 sounds like a bit too much initial.I try and run 10 to 15 with 36 all in.Rocky
Chrysler Firepower
[Re: therocks]
#120727
09/14/08 11:13 PM
09/14/08 11:13 PM
RapidRobert
YES what they said. Ground the coil wire & crank it you'll know right away. If your timing is where you want it I would add an ign kill switch & get it cranking then switch on the ign. Worked for us on our stock car when it was hot.
[Re: HealthServices]
#120728
09/14/08 11:44 PM
09/14/08 11:44 PM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
FYI I'm running at 22-23 initial as well and it starts fine when hot. Perhaps the OP getting kickback is a sign that it's an ignition issue as opposed to just battery cables not carrying the juice?
[Re: Exit1965]
#120730
09/15/08 01:05 AM
09/15/08 01:05 AM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Sorry did not want to appear like I was attacking you. I just want to exhaust the free checks that do not involve money first. I assume you have a header on your car as well, maybe designed a little better than mine and it does not heat the starter as much when it gets hot.
My Starter will start my 440 as well with timing, hot. But this car also kills starters (with it's header design) and I have notice that when the initial timing is not as high or if I use a kill switch, the starter will live a whole lot longer.
I'm not a fan of replacing starters with headers or getting anywhere near the thing if I don't have to.
[Re: mike_vango]
#120731
09/15/08 05:06 AM
09/15/08 05:06 AM
Posts: 375 NE Oklahoma
71valiant
NE Oklahoma
do you have the old style starter and headers?
Yes big old starter and headers. Dont let anyone tell you it wont go in! It was a very tight fit though.
[Re: Exit1965]
#120732
09/15/08 05:07 AM
09/15/08 05:07 AM
71valiant
NE Oklahoma
If the battery cables are old, they could be the culprit. I had the same problem on my car, except there was no kickback, just very laborous cranking when it was hot. Put some 2 gauge cables on from Autozone (both for under $20) and now it spins over very fast at any temp.
Thanks I will try that.
#120733
09/15/08 05:10 AM
09/15/08 05:10 AM
71valiant
NE Oklahoma
The timing is set to 23 initial
Try a ignition kill when you start or hook up a timing retard (like one sold by MSD) and switched on (retard mode to 10-12 btdc) whenever the starter is engaged.
Before you change try this out by: starting the car Let it warm up.retard timing to about 12 initial. shut car off waitStart car.
If this works you know it is your timing and you need to either retard it and recurve put a timing retard when you start the car or a ignition kill
See I've been thinking it was timing all along. Its got a pretty healthy cam in it for having stock pistons. So it likes all that timing. I'll try retarding it and see how it restarts. Thanks
[Re: 71valiant]
#120736
09/15/08 01:41 PM
09/15/08 01:41 PM
So twenty three of initial is fine if you have a big enough cam that will bleed off pressure while cranking. My race car is locked down at 35 But I have 306 advertised and 272 at .050 duration. I would star by putting your total timing back to 34 or 35 degrees thats all thats nessesary on a mopar. If its running better with that much timing its probably to rich on the carb and you are needing sooner ignition to get the fuel burnt . That will take your initial down 3 or 4 degrees then see how it starts when hot. The increased initial timing is to give a better signal to the carb when you have large overlap cams. Once you get the timing where the car starts while hot then adjust the carb. www.4secondsflat.com has a tuneup guide that explains all this and how ignition and fuel curves effect each other ![](/ubbthreads/images/graemlins/apimp.gif)
