Too much gear? #1206779
03/31/12 01:27 AM
03/31/12 01:27 AM
West Michigan
76318dart Offline OP
West Michigan
Okay I have a couple of questions. First heres my combo:
340 with 4inch stroker crank
10:5 compression
571/571 248/254 hyd roller
Rhs heads 2.02/1.625
air gap intake
pro systems carb 830cfm
904 with a turbo action 10in
410 gears.
okay well i got it to run a 11.60 @ 113. It seems like it is falling on its face after the 1/8 mile.
my 60ft is a 1.56 and my 1/8 is 7.30 at 92. I run a 27 in tall tire. it just seems like I have too much gear, because i shift it at 6500 and go through the traps at 6400, but anything over 6200 it seems to loose power so what gears would you recomend for it? or what else would you change? I am running a mechanical fuel pump a 120 gph carter.I have msd 6al and distrubtor.thanks for looking. just need some ideas
76 dart 318 runs 12.9o @ 103 mph with 1.78 60ft.
Re: Too much gear? [Re: 76318dart] #1206780
03/31/12 01:51 AM
03/31/12 01:51 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
what you got for a fuel system? may be running out of fuel.
Re: Too much gear? [Re: dartman366] #1206781
03/31/12 05:25 AM
03/31/12 05:25 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
next time out try shifting at 5800 , then next pass 6000 . See what it does
Re: Too much gear? [Re: 76318dart] #1206782
03/31/12 06:28 AM
03/31/12 06:28 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
what size chip/limiter is in the ignition..
what does the plugs look like..
how much timing...
may also want to switch to a 28" tall tire...
Re: Too much gear? [Re: smokinwoody] #1206783
03/31/12 07:24 AM
03/31/12 07:24 AM
West Michigan
West Michigan
im running 3/8 fuel line with carter mechanical and my chip is a 6800. and my timing is set at 38 total and i have done 36 with no difference. I was thinking 28 in tall tire just have to cut to make room for that size lol.
Re: Too much gear? [Re: 76318dart] #1206784
03/31/12 08:24 AM
03/31/12 08:24 AM
Minnesota
Coldart Offline
Coldart  Offline
Minnesota
w/cam you got - motors probably done @5500rpm or less.
w/4" arm need more duration for more rpms.
numbers are about right for your combo.
Taller gears.
Re: Too much gear? [Re: Coldart] #1206785
03/31/12 08:53 AM
03/31/12 08:53 AM
West Michigan
West Michigan
Okay thanks. What gears you thinking?
Re: Too much gear? [Re: 76318dart] #1206786
03/31/12 09:39 AM
03/31/12 09:39 AM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
How heavy is your car? I think your gearing is OK, Changing to 3.91 would not make much difference. A 29 tall tire would be your best bet.
What converter stall and how much slip?
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: Too much gear? [Re: 76318dart] #1206787
03/31/12 09:39 AM
03/31/12 09:39 AM
NC
440Jim Offline
440Jim  Offline
NC
410 gears.
I run a 27 in tall tire. it just seems like I have too much gear, because i shift it at 6500 and go through the traps at 6400...
Looks like 10-11 percent converter slip at the finish line. That is too much IMO. If you get a converter with 6 percent slip, the trap RPM would only be 6100 rpm.
If you can get a 28" tall tire in there, that would help about 200 rpm.
With the small cam duration,limited head flow and hydraulic cam, it might not like too far over 6000 rpm. What valve spring pressures (seat and open) do you have? Too little will kill higher rpm power.
Re: Too much gear? [Re: 440Jim] #1206788
03/31/12 10:06 AM
03/31/12 10:06 AM
West Michigan
West Michigan
My car weighs 3250 w/me. the converter stalls around 3800. And im not sure about my springs I know they are comp behive springs. And might be installed at 1.81? Im at work ill have to look when I get home.
Re: Too much gear? [Re: 76318dart] #1206789
03/31/12 10:35 AM
03/31/12 10:35 AM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
I've heard strokers don't like as much timing as the 340/360. I have mine at 32, I haven't messed with it since I installed the engine, Just working on the rest of the combo.
Re: Too much gear? [Re: DragDart360] #1206790
03/31/12 10:56 AM
03/31/12 10:56 AM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
I would check fuel system and valve springs. My thought is 4.10 gear is not the problem. The 60' is slow and with 3.91s it may get worst. Car should go alot faster.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: Too much gear? [Re: slippery440] #1206791
03/31/12 11:12 AM
03/31/12 11:12 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
my 408 likes 32-33 degrees of total timing, I still think you are running out of fuel, a 3/8 line and a carter pump to me isn't suffecient, I know mine likes to eat, I really don't think your gearing is off that far, alot of other factors play into the whole combination, like cam,springs timing, cam centerline, fuel delivery etc.
Re: Too much gear? [Re: 76318dart] #1206792
03/31/12 11:18 AM
03/31/12 11:18 AM
NC
440Jim Offline
440Jim  Offline
NC
The correct Comp Beehive springs should be good, if installed at the correct height.
Re: Too much gear? [Re: 76318dart] #1206793
03/31/12 11:35 AM
03/31/12 11:35 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont think its the gear either... as said... check
your fuel supply... also with the timing set it at
the minimum that it doesnt slow down not the max...
what is the cam installed at(did you degree it)
Re: Too much gear? [Re: MR_P_BODY] #1206794
03/31/12 11:41 AM
03/31/12 11:41 AM
West Michigan
West Michigan
Okay I was thinking of upgrading my fuel system. My cam was installed at 108 or 107 if i remember correctly and it was degreed.
Re: Too much gear? [Re: 76318dart] #1206795
03/31/12 12:10 PM
03/31/12 12:10 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Mount a fuel gauge on the cowl to be sure.
Sheldon
Re: Too much gear? [Re: RUNCHARGER] #1206796
03/31/12 12:19 PM
03/31/12 12:19 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
Check/upgrade the needle and seat size in the carb too.
Damon
Re: Too much gear? [Re: 76318dart] #1206797
03/31/12 11:16 PM
03/31/12 11:16 PM
Cab_Burge Online work
Cab_Burge  Online Work
One sure way to check your fuel system s o jet the carb up several jets sizs at the track and see if goes faster or slower on the 1/4 MPH, if it doesn't change you probally have a fuel delivery VOLUME problem One other thing IO would try is to back the timing down to 32 to 33 degrees total(above 4500 RPM )Let us know what you find
Re: Too much gear? [Re: 76318dart] #1206798
04/01/12 12:38 PM
04/01/12 12:38 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Those heads have really efficent combustion chambers and do not need as much timing as old fashioned open chamber SB heads, bump the timing down to 32 or so total.
Also need to upgrade the fuel system
