BB aftermarket A/C guys, need imput #1206745
03/30/12 10:39 PM
03/30/12 10:39 PM
west palm beach, florida
modelmakerinc Offline OP
Hey guys, looking into changeing my Fury around a bit and I am considering doing an aftermarket A/C system. The car has had its A/C and heater core gutted, it is only there as a blower for the windshield but it is a factory A/C car so I have ducting. My biggest concern is really in mounting the compressor and getting a quality system.
What systems are you running, good and bad aboiut them and pictures would be very helpful mostly compressor, brackets and pulleys. Thanks here is the motor i will be bolting it to
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: BB aftermarket A/C guys, need imput [Re: modelmakerinc] #1206746
03/30/12 10:44 PM
03/30/12 10:44 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
http://www.bpemopar.com/ very good stuff
Re: BB aftermarket A/C guys, need imput [Re: CSK] #1206747
03/30/12 11:01 PM
03/30/12 11:01 PM
IN
ahy Offline
ahy  Offline
IN
Agree Bouchillon is good. Also Classic Auto Air. Classic can rebuild your original heat/AC in car unit... although it could be expensive if a lot of parts are missing. Either can supply also supply a new evaporator/heater unit.
Re: BB aftermarket A/C guys, need imput [Re: ahy] #1206748
03/30/12 11:57 PM
03/30/12 11:57 PM
NY
Beep Beep Offline
Beep Beep  Offline
NY
I have a 69 RR A/C car that was missing every A/C component under the hood. Not a big deal. Call Bouchillon ask for Randy. Great guy and very helpful. The kit comes with everything and it works great. You will need an A/C shop to bubble crimp the hoses. I did have everthing inside the car. I even repaired my connections that came out of the firewall. When they removed the A/C from my car they cut the lines at the fire wall. I guess they did not own big wrenchs for the fittings.
Re: BB aftermarket A/C guys, need imput [Re: Beep Beep] #1206749
03/31/12 12:02 AM
03/31/12 12:02 AM
NY
Beep Beep Offline
Beep Beep  Offline
NY
There are some very good pics on Randy's website. Be careful with which brackets you buy. Read all the notes on Randy's site. You need the correct pulleys, water pump to make the alignment work. You can buy a new heater core from a place in Texas, I can't remember the name. If you need it I will look it up. Not sure if you can find a new evaporator. You might considered looking for a complete heater box setup. You can have an old heater core rebuild. There is a place near fort lauderdale that does them.
Re: BB aftermarket A/C guys, need imput [Re: Beep Beep] #1206750
03/31/12 02:54 AM
03/31/12 02:54 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you're not too picky about which a/c kit you buy, you can get a good deal. I got a steal of a deal on a new/complete under dash heat/ac kit made by nostalgic auto air. It's got ports on the sides I can hook hoses up to for windshield vents too.
