small block indy head or 3g Hemi #1206647
03/30/12 07:51 PM
03/30/12 07:51 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Which to build?
I am looking for around 700 hp out of my R3 11.5 440 cid 4.25 stroke crank, Hydraulic cam 230 CNC indy heads.
Is it possible or do I sell everything and and start with an aluminum G3 4.25 stroke apache head hydraulic 450 cid 11.5.
I have 3 sets of G3 heads first generation 5.7, eagle and apache .
Selling my Indy stuff would get me an aluminum G3.
Re: small block indy head or 3g Hemi [Re: MattW] #1206648
03/30/12 08:27 PM
03/30/12 08:27 PM
houston texas
gremlinsteve Offline
houston texas
i know the 6.1 head can reach the 400 cfm range on a stock valve.
the apache ca hit the 430-440 range also. more than enough i think for that power level.
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: small block indy head or 3g Hemi [Re: MattW] #1206649
03/30/12 08:31 PM
03/30/12 08:31 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I am going to guess that 700 is pretty optimistic for a hydraulic cammed 440 unless you are into power adders.
It would take compression and great heads to get close and even then I don't think it would be attainable.
I know nothing about Gen III stuff , so I'll leave that one to those who do.
I might be close with my 405.....I'll find out soon enough.
But that is a solid roller , W-9's and 12-1.
Re: small block indy head or 3g Hemi [Re: tubtar] #1206650
03/30/12 09:15 PM
03/30/12 09:15 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
The 392 production motor is already around 500 hp. What would be so hard to make a 426 or 440 stroker make 700 hp? The Apache heads flow great out of the box. Cubes, compression, cam...stir it up, add some race fuel.
[image][/image]
Re: small block indy head or 3g Hemi [Re: sgcuda] #1206651
03/30/12 09:31 PM
03/30/12 09:31 PM
Out West
408strokerdart Offline
Out West
Do the 3g hemi. It will get there easily with the hydraulic roller and you will be more than 100 lbs lighter.
Re: small block indy head or 3g Hemi [Re: 408strokerdart] #1206652
03/30/12 10:53 PM
03/30/12 10:53 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I don't have anything near 700 hp, but if I were starting over I would build a 3g. The heads are amazing for the money, everything else is pretty much a wash ($$) with the exception of good rocker gear.
Re: small block indy head or 3g Hemi [Re: justinp61] #1206653
03/30/12 11:04 PM
03/30/12 11:04 PM
BPE Offline
BPE  Offline
I think either would be cool but if it was me I would build a hemi. The parts seem to be alot more reasonable overall.
Rod
Re: small block indy head or 3g Hemi [Re: MattW] #1206654
03/30/12 11:12 PM
03/30/12 11:12 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: small block indy head or 3g Hemi [Re: sgcuda] #1206655
03/30/12 11:28 PM
03/30/12 11:28 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
The only potential obstacle to reaching 700 h.p. in either case would be the hydraulic cam.......I am assuming we are talking N/A.
Probably easier with the Hemi I think , so if you can cash out of the parts you already have , it makes sense.
Re: small block indy head or 3g Hemi [Re: tubtar] #1206656
03/31/12 12:01 AM
03/31/12 12:01 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I agree,the heads will do it with the right combination.With a hydraulic it will take getting everything scienced out to a higher degree to make it work. A lot of compression and a big solid roller make things easier,that is why most people go that route,IMO.
Keith
Re: small block indy head or 3g Hemi [Re: Dunnuck Racing] #1206657
03/31/12 12:49 AM
03/31/12 12:49 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
sound like you got 700+ with our LA stuff you might need a soild roller thought. who makes a solid roller for a late hemi. 700 hp is alot to ask for from a non solid cam ?? just saying
Re: small block indy head or 3g Hemi [Re: WHITEDART] #1206658
03/31/12 02:01 AM
03/31/12 02:01 AM
SoCal
Brian Hafliger Offline
SoCal
Just sayin...
http://www.popularhotrodding.com/tech/1103phr_bes_417ci_gen_iii_hemi/index.html
Brian Hafliger
Re: small block indy head or 3g Hemi [Re: Brian Hafliger] #1206659
03/31/12 02:06 AM
03/31/12 02:06 AM
houston texas
houston texas
remember that 340 rick just made 580 at the wheel on his ride. thats a 426 car with a hydraulic cam. add in a 18 percent dt loss and thats right around 680 crank hp...on pump gas
steve
Re: small block indy head or 3g Hemi [Re: gremlinsteve] #1206660
03/31/12 02:07 AM
03/31/12 02:07 AM
houston texas
houston texas
i cammed shafi keislers car. it made in the range of about 575 at the wheel. with not a whole lotta cam
Re: small block indy head or 3g Hemi [Re: MattW] #1206661
03/31/12 08:17 AM
03/31/12 08:17 AM
The Great White North
RAMM Offline
RAMM  Offline
A 440 ci 11.5 comp R3-LA with your 230 Indy's will more than likely come very very close with the right camshaft. At those cubes a hydraulic roller will not give up ANYTHING to a solid roller (due to the rpm range) . Why don't we just call Johnson/Hylift and order up some of their way cool short travel drop in hydro-rollers and think long and hard about the valve events. Your intake will need attention. I recall your previous 416 made well over 600hp (at a similar comp ratio) with those heads so it stands to reason that with more cubes that 700 hp is more than possible. I say build since you have a lot of the components already--and sell it if you still want to explore the 3g Hemi. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: small block indy head or 3g Hemi [Re: Brian Hafliger] #1206662
03/31/12 12:17 PM
03/31/12 12:17 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Just sayin...
A couple cubic dollars in that one , but she is a serious torque manufacturing machine.
My gut feeling is that is you are contemplating selling one package to buy the other , this build might be out of reach unless you are both patient and frugal.
Re: small block indy head or 3g Hemi [Re: tubtar] #1206663
03/31/12 02:21 PM
03/31/12 02:21 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Just sayin...
Leon441 posted this awhille back.
The BES engine masters engine had some tricks but, obviously nothing that could not be bought. Tony offered that engine with fuel injection for $10,000. How can you complain about a price like that.
Leon
Re: small block indy head or 3g Hemi [Re: MattW] #1206664
03/31/12 02:37 PM
03/31/12 02:37 PM
Toronto
mshred Offline
mshred  Offline
Toronto
I would try and go the route of the new hemi, they just seem to be awesome motors...Nothing wrong with LA's, but it seems like the Hemi's have the head foundation (and blocks too) to make gobs of power for alot less work and money than any LA would take.
I think the toughest thing would be having to sell the LA stuff you have and make up enough money to fund the Hemi. I say go for it though! I'd like to do one myself someday as you already know
Good luck man! And if you start a build on one, keep us posted how it goes!
Re: small block indy head or 3g Hemi [Re: mshred] #1206665
03/31/12 03:18 PM
03/31/12 03:18 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Matt you've been all about the Gen 3 hemi for long enough to where I can't imagine you doing anything anything else.
If all the LA stuff was up for sale reasonable enough, I'm sure it'd be sold in no time.
Rich H.
Esse Quam Videri
Re: small block indy head or 3g Hemi [Re: MattW] #1206666
03/31/12 04:23 PM
03/31/12 04:23 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Leon
Actually , the dual distributor drive is a one off and I doubt there is anything like it in production.
But my understanding of the Engine Masters efforts is they they really are purpose built and long term reliability is a secondary concern.
Not a deal breaker for a race motor , but dual purpose or street applications will likely lead to disappointment.
Yeah........I'd say 10 K , if that included the ignition and computer for the fuel injection is a steal.
Without those two would be a bargain.
But it may not be the right tool for every customer's job.
And there's nothing worse than trying to tighten an allen head cap screw with a phillips screw driver.
