1972 Plymouth B body disc brake rotor #1206599
03/30/12 05:30 PM
03/30/12 05:30 PM
California
moparbroz Offline OP
California
What is interchangable that is also offered for other Mopar models? Anything modern like a Jeep? I heard '73 plus systems are cheaper. I have the original front disc brake system from my Satellite. I need the dust shields too. Thanks!
Hebrews 11:1
Re: 1972 Plymouth B body disc brake rotor [Re: moparbroz] #1206600
03/30/12 05:34 PM
03/30/12 05:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The rotors are 70-72 B/E specific ... $$$$$$
Dr. diff sells a spacer for the 73 up inner bearing so you can use the 73 up rotor ...
same as a jeep ??? thanks for the laugh , i needed that ...
Re: 1972 Plymouth B body disc brake rotor [Re: JohnRR] #1206601
03/30/12 06:01 PM
03/30/12 06:01 PM
California
California
Ha ha. The reason I asked about modern Jeep is they look simular so.....glad I could help you out with a mid day chuckle!! Thanks!
Hebrews 11:1
Re: 1972 Plymouth B body disc brake rotor [Re: JohnRR] #1206602
03/30/12 06:17 PM
03/30/12 06:17 PM
Central TX
roe Offline
roe  Offline
Central TX
There are deals to be had. I picked up stock style replacements (not drilled/slotted) off Ebay for about $75 each. I was able to get 2 for less than what the parts stores are wanting for 1. They were very nice pieces that bolted right on and have performed flawlessly.
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
