LIP seal? DOOR EASE? #1206541
03/30/12 04:20 PM
03/30/12 04:20 PM
GoDartGo Offline OP
GoDartGo  Offline OP
My tranny book says to use DoorEase when putting the
piston back in the overriding clutch.
Can't find any, what else will work in it's place?
Re: LIP seal? DOOR EASE? [Re: GoDartGo] #1206542
03/30/12 04:26 PM
03/30/12 04:26 PM
vaseline & it's compatible w tranny fluid
Re: LIP seal? DOOR EASE? [Re: RapidRobert] #1206543
03/30/12 05:55 PM
03/30/12 05:55 PM
GoDartGo Offline OP
GoDartGo  Offline OP
Thanks, I'll give it a try.
Also I thought I read in the book that the space between the select ring and the
top plate for the front clutch is suppose to be around .056-.068 . But now I can't
find where it says that. Is .056 to .068 right?
