HEMI ENGINE BUILDER QUESTION
#1206446
03/30/12 02:03 PM
03/30/12 02:03 PM
Posts: 1,505 TN
SCATPACK 1
TN
This is directed to the experienced Engine Builders. Regarding the thickness of the piston dome or surface. We are working with a 572 Hemi and Indy's newest designed Hemihead, their HIPO head that has 2.40 intake valves flowing 450 with a roller cam 278/282* @50 with 800 lift. Shooting for just under 14-1 compression. My brother just received a second set of Weisco Pistons and they do not have the valve to piston clearance he requested again. He was very specific with the person he spoke with on what we were using for the head and cam combo. Here is my question, IF I machine the intake valve side of these pistons to clear the intake valves, what is my minimum piston thickness on the dome/valve relief? Can we go down to 100 thousands or should we try to maintan at least 200 thousands for piston dome/deck thickness. I want at least 90 thousands piston to valve clearance on the intake valves but to get this, we will have to cut the reliefs about 200 thousands. Both sets of pistons the mfg has sent to us, there is zero clearance on the intake valves even without the cam opening the valves. PLENTY of clearance on the exhaust, but they can't seem to get the intake valve area right. The intake valve on these HIPO heads appear to sit further out of the combustion chamber, but I don't have another set of heads to compare them to. The person on the phone at Weisco said they had a piston designed just for this head but it does not seem they fit very well. I have not miked the thickness of the piston dome yet, so I don't even know if I can cut them this much. What say the experts on these pistons, How thin can you safely run the piston surface/dome area before you experience breakage.
Old Geezer Racing
Re: HEMI ENGINE BUILDER QUESTION
[Re: quickd100]
#1206448
03/30/12 02:19 PM
03/30/12 02:19 PM
Posts: 13,362 Marion, South Carolina [><]
an8sec70cuda
I think I'd send them back to Wiseco and get my money back. Then go to a piston manufacturer who knows what they're doing. Or just call Dan (DRAM) at Performance Only and he'll hook you up w/ a good set of Diamond pistons.
[Re: SCATPACK 1]
#1206456
04/02/12 11:33 PM
04/02/12 11:33 PM
Posts: 914 tn
robnbird
tn
WHAT DO YOU THINK ABOUT MAKING A MOLD OF THE C/ CHAMBER AND SEND IT TO SAY J&E TO MAKE A SET. HUM THAT WILL WORK. I JUST WANT TO ASK A QUESTION? ARE YOU ONE OF THE ORIGINAL SCAT PACK GUYS HERE IN TN FROM BACK AROUND 1970.
[Re: robnbird]
#1206458
04/04/12 06:54 PM
04/04/12 06:54 PM
Posts: 1,505 TN
SCATPACK 1
TN
Yes I was. Boy does that picture bring back memories. Where did you come up with that old Drag Review photo. That pic is from an IHRA Points meet. We had won several IHRA Superstock races in a row and Jimmy Johnson, the IHRA publicity director guy did an article on my car with the best 4 speed driver in the south. Feared by many including Roy Johnson, John Wayne and Clint Eastwood (but don't tell him I said so) LOL
Old Geezer Racing
[Re: SCATPACK 1]
#1206459
04/04/12 07:05 PM
04/04/12 07:05 PM
Posts: 914 tn
robnbird
tn
I thought you were one of those guys.and yes that guy could flat drive, I never saw anyone any better
[Re: Performance Only]
#1206460
04/06/12 07:20 PM
04/06/12 07:20 PM
Posts: 276 Temecula, Ca.
zzyzxpat
Temecula, Ca.
You did mine Dan for a stroked 361. You were a gentleman to deal with, gave me alot of info, and was very pleased with the price, service, and quality.
Pat
" The last official act of any goverment, is to loot the treasury" George Washington
