Cleaning heavy brake dust deposits off a chrome wheel? #1206304
03/30/12 03:18 AM
03/30/12 03:18 AM
Sarcoxie, MO, USA
MoPar Jamie Offline OP
Sarcoxie, MO, USA
Hey all,
I have a chrome steel wheel that is going on my '85 shortbed. It was originally off my '95 Van and it had a locked caliper. So the brake dust is really caked on bad. I got it to shine a little better but there are a lot of areas that are grey.
Tried rag and water and then some brake cleaner. Didnt help. So what can I use to clean this wheel? I got the back ones looking great because they were dust free but I cant get this one clean.
Here is a pic of the truck with the wheel on it. You can see what I am dealing with.
Ideas? Tips?
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: Cleaning heavy brake dust deposits off a chrome wheel? [Re: MoPar Jamie] #1206305
03/30/12 07:26 AM
03/30/12 07:26 AM
IN
ahy Offline
ahy  Offline
IN
I've found the wheel cleaner spray + elbow grease to be pretty effective on brake dust.
Re: Cleaning heavy brake dust deposits off a chrome wheel? [Re: MoPar Jamie] #1206306
03/30/12 09:54 AM
03/30/12 09:54 AM
Indiana
GrnMagic77 Offline
Peter Parker
GrnMagic77  Offline
Peter Parker
Indiana
Not sure what the finish is like on your wheel but I have used heavy duty toilet bowl cleaner in the past with very good results.May be overkill for your application though,some of them have about a 20% base of hydrochloric acid which eats through just about anything,maybe even the wheel itself if left on long enough.
Use gloves,wipe it on and be sure to rinse thoroughly...has worked well for me.Better to test a spot first,if you have dull gray areas it sounds like the chrome itself may have a problem.
1978 Round Up-1977 Warlock-1977 Powerwagon Adven.- 1976 Blue "Macho"-1974 Charger-1968 Fury III -1966 Newport *
Re: Cleaning heavy brake dust deposits off a chrome wheel? [Re: GrnMagic77] #1206307
03/30/12 12:38 PM
03/30/12 12:38 PM
md
mopars4ever Offline
mopars4ever  Offline
md
mothers mag wheel polish should work along with a lot of rubbing
Re: Cleaning heavy brake dust deposits off a chrome wheel? [Re: mopars4ever] #1206308
03/30/12 01:23 PM
03/30/12 01:23 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
Yep try chrome polish in any brand. It worked on my wife's Suburban.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Cleaning heavy brake dust deposits off a chrome wheel? [Re: MoPar Jamie] #1206309
03/30/12 02:16 PM
03/30/12 02:16 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
SOS pad. Been using them for years on chrome wheels. Cleans them up real good, and easy too.
Does not harm the chrome finish at all. Try it on a very small section first if you are worried about damaging the wheel.
Re: Cleaning heavy brake dust deposits off a chrome wheel? [Re: 318 Stroker] #1206310
03/30/12 10:09 PM
03/30/12 10:09 PM
