Do they repro this? #1206299
03/30/12 01:23 AM
03/30/12 01:23 AM
Western NY
19SuperBee70 Offline OP
Western NY
Does anyone repro a 70 b body driver side fresh air flap gasket? Not the gasket that goes from the fresh air box to the cowl. the flap inside the box is metal with a rubber gasket bonded to the edges. Does anyone repro the rubber gasket?
Re: Do they repro this? [Re: 19SuperBee70] #1206300
03/30/12 05:50 AM
03/30/12 05:50 AM
White Hall, Maryland
MD72 Offline
MD72  Offline
I don't know if this helps?http://shop.detroitmuscletechnologies.com/main.sc
70 Road Runner Air Grabber Door Seal Gasket
We ARE the Manufacturer! Detroit Muscle Technologies reverse engineered, laser cut, OEM style material air grabber door to hood seal for your 1970 Road Runner and 1971 / 1972 Dodge Charger. The door to hood gasket is cut from an automotive spec, black sponge rubber gasket material.
Re: Do they repro this? [Re: 19SuperBee70] #1206301
03/30/12 09:42 AM
03/30/12 09:42 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
No
