Re: Motor to Trans Alignment
[Re: Beep Beep]
#1206279
03/30/12 02:31 AM
03/30/12 02:31 AM
Posts: 43,311 Bend,OR USA
Cab_Burge
Let me get this straight. Currently I have the motor out of the car on an engine hoist. I am going to mount the flywheel and bell housing. Mount the magnetic base to the flywheel and turn the crank. Sorry I am a stuck on the total run out part. Do I mark the bell housing at 12,3,6,9 o'clock and check the readings at all points.
That part always drive me nuts, I try to find the low or high spot to set the dial indicator to zero and then turn it and watch, write the numbers on each 1/4
