Re: carb spacer question
[Re: Dougsmopars]
#1206244
03/30/12 09:09 PM
03/30/12 09:09 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Everything I have read says 4 hole spacer for street use, even with a single plane intake. Raising the carb up off the intake has a slight tunnel ram effect that helps performance (at least in theory). But their main purpose (when constructed of wood or phenolic) is keeping heat away from the carb to avoid hard hot restarts. I have a 4 hole 1/2" phenolic on top my stock iron 340 intake and also a 4 hole 1/2" phenolic on top my LD340 on my 360. In my case (A bodies) that's all I can get without cutting the hood for more clearance.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
