carb spacer question #1206241
03/29/12 10:12 PM
03/29/12 10:12 PM
dark side of the moon
Dougsmopars Offline OP
440 big cam (no cam info was in motor when i bought the car) Stock cast 4 hole intake. Pro's and cons of useing a carb spacer. None 1 or 2 inch?
Re: carb spacer question [Re: Dougsmopars] #1206242
03/29/12 10:27 PM
03/29/12 10:27 PM
I have used a open one inch, two inch four hole, two inch opened and a two inch reversion spacer on variuos motors over the years, none of the motors DIDN'T like them In other words your motor should like a spacer Sorry I can't tell you which size and type will work best for you
Re: carb spacer question [Re: Dougsmopars] #1206243
03/30/12 06:33 AM
03/30/12 06:33 AM
places
79powerwagon Offline
places
There is no answer beyond trial and error. If you are running a AFB after-market carb, the manuals even tell you to use a 4 holer, which they LOVE! Since this is my preference for carbs, I have a pile of 1/4" 4 hole spacers that I stack up to find the best height for my particular engine (and no two have been the same). Once I have found the "sweet spot, I buy a phenolic spacer of that thickness and run that.
Re: carb spacer question [Re: Dougsmopars] #1206244
03/30/12 09:09 PM
03/30/12 09:09 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Everything I have read says 4 hole spacer for street use, even with a single plane intake. Raising the carb up off the intake has a slight tunnel ram effect that helps performance (at least in theory). But their main purpose (when constructed of wood or phenolic) is keeping heat away from the carb to avoid hard hot restarts. I have a 4 hole 1/2" phenolic on top my stock iron 340 intake and also a 4 hole 1/2" phenolic on top my LD340 on my 360. In my case (A bodies) that's all I can get without cutting the hood for more clearance.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
