Subframe connectors any reasons not to have them? #1206170
03/29/12 09:01 PM
03/29/12 09:01 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
My 69 road runner cowl started to crack near the windshield so before I fix and repaint the area I am pretty sure it's time for sub frame connectors.
I am taking the car down next week to my friends muffler shop to get a custom made exhaust system and my buddy said he can weld me up a set of sub frame connectors at the same time. He said he has done a few of them on E-bodies and he uses 1 x 2 box tubing. He showed me some photos and it's a pretty nice clean look.
So this all sounds good but I was just wondering if there are any downsides to having them installed?
Thanks for any opinions
Stu
Re: Subframe connectors any reasons not to have them? [Re: MidPenMopar] #1206171
03/29/12 09:12 PM
03/29/12 09:12 PM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
None that I know of. I had them on my 69 Bee and it was noticeably stiffer.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: Subframe connectors any reasons not to have them? [Re: MidPenMopar] #1206172
03/29/12 09:14 PM
03/29/12 09:14 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
I've had them on my Duster for almost 10 years now. No cons here. Easier to jack the car up, drives better on the road, launches straighter at the track.
Re: Subframe connectors any reasons not to have them? [Re: dustergirl340] #1206173
03/29/12 09:21 PM
03/29/12 09:21 PM
Ok that all sounds pretty positive!
Re: Subframe connectors any reasons not to have them? [Re: MidPenMopar] #1206174
03/29/12 09:33 PM
03/29/12 09:33 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Put 'em on. I would also look around for broken spot welds around the front sub-frames. Tighten the whole thing up.
Re: Subframe connectors any reasons not to have them? [Re: Jim_Lusk] #1206175
03/29/12 09:39 PM
03/29/12 09:39 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Just happen to have a set of competition engineering connectors for B body that I got for my runner and never got to use because I sold the car as a project. PM me if interested.
Re: Subframe connectors any reasons not to have them? [Re: MoparforLife] #1206176
03/29/12 09:57 PM
03/29/12 09:57 PM
Ok I PMed you!
Re: Subframe connectors any reasons not to have them? [Re: MidPenMopar] #1206177
03/29/12 10:03 PM
03/29/12 10:03 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Only reason to me is if your building a totally stock original car... this wouldn't fit for your car
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Subframe connectors any reasons not to have them? [Re: Silver70] #1206178
03/30/12 12:30 AM
03/30/12 12:30 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Look at the subframe connector threads in the Cornering forum here. I doubt that 1x2 tubing would add that much torsional stiffness. The cowl crack is probably due to a hidden defect from the time the car was built or because of a collision long ago. I recall reading your posts, as I remember, you don't stress your car very much. The connectors may be a waste of effort and $$ if you drive conservatively.
Re: Subframe connectors any reasons not to have them? [Re: Kern Dog] #1206179
03/30/12 12:43 AM
03/30/12 12:43 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I pretty much agree with this.. Stu you probably don't drive aggressively enough to justify subframe connectors but if you want to add them I don't see any reason not to... But if your gonna do it 1"x2" material isn't worth the trouble.... most guys use 2"x2" or 2"x3"...
Re: Subframe connectors any reasons not to have them? [Re: 1_WILD_RT] #1206180
03/30/12 01:06 AM
03/30/12 01:06 AM
Ok that's what i was looking to find out as to what is the way to go on them. Here's a set that Summit sells for $150.
http://www.summitracing.com/parts/CEE-3117/All/
Re: Subframe connectors any reasons not to have them? [Re: MidPenMopar] #1206181
03/30/12 01:34 AM
03/30/12 01:34 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: Subframe connectors any reasons not to have them? [Re: 1_WILD_RT] #1206182
03/30/12 01:38 AM
03/30/12 01:38 AM
If your gonna do it consider these..
https://store.uscartool.com/66-70-B-Body-Frame-Connectors_p_13.html
A picture of them installed..
http://www.uscartool.com/img/70Superbird/index.html
Ok now i see how they did it. Looks like a very nice job on that Superbird.
Re: Subframe connectors any reasons not to have them? [Re: MidPenMopar] #1206183
03/30/12 02:03 AM
03/30/12 02:03 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I used the 2x3" square tube. Slot open the front part of the rear sub-frame and the square tube slides right in nicely so you can weld it all back together. Only downside to doing it this way is in the back seat feet area the tube comes thru the floor by about 1". It gives a real nice increase in torsional rigidity. Some guys cut the tube to fit the floor's contour, I don't like this because the thinner the tube gets and less rigid it is.
Re: Subframe connectors any reasons not to have them? [Re: DaytonaTurbo] #1206184
03/30/12 09:59 AM
03/30/12 09:59 AM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
2X2 1/8" square stock tubing on mine.
Re: Subframe connectors any reasons not to have them? [Re: dustergirl340] #1206185
03/30/12 12:10 PM
03/30/12 12:10 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
this is how i did mine. i could feel that they were there in the first hard corner i took.
http://www.bigblockdart.com/techpages/connectors.shtml
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Subframe connectors any reasons not to have them? [Re: DaytonaTurbo] #1206186
03/30/12 12:47 PM
03/30/12 12:47 PM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
This is the exact way I do it!
Re: Subframe connectors any reasons not to have them? [Re: MidPenMopar] #1206187
03/30/12 03:26 PM
03/30/12 03:26 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Be sure to add the 4 torque boxes when you add the sub-frame connectors. You may want to consider putting in a lower radiator support while your under there too.
I set mine back enough to clear the radiator tank on my '68. It's easier to put in that way, less intrusive and can be removed pretty easily in the future should the need arise.
You can see it tieing the bottom of the front frame rails together down in there just in front of the fan belt
Re: Subframe connectors any reasons not to have them? [Re: rabid scott] #1206188
03/30/12 03:55 PM
03/30/12 03:55 PM
BDW Online content
BDW  Online Content
Looks good, I've always wondered why no one notches the rear portion so it doesn't stick so far through? Would there still be enough rigidity?
Re: Subframe connectors any reasons not to have them? [Re: BDW] #1206189
03/30/12 04:06 PM
03/30/12 04:06 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Any connector, even 1x2 is better than none! I'd go the go the non invasive route on Stu's car if it was mine. no need to cut into the floor pan to gain benefits.
Last set I made were 2x2 .090 wall IIRC. They make a big difference in ride quality. .125 wall is overkill in almost every situation except stout race cars.
